2.4l 6 speed axle ratio questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2.4l 6 speed axle ratio questions
Zone Offroad - Jeep Forum PromotionFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 04-14-2015, 04:59 PM   #1
bj26pro
I currently have 3.73 gears and i can't keep hwy speeds. I have 31" durtracks and am wanting to go to a 33" once I have enough cash for them. I'm and going to regear for the 33"s and put a Ox locker in the front. Planning on regearing and running the 31"s till they where out. Just trying to figure out what ratio I want to go. Any input is welcome
bj26pro is offline   Reply With Quote Quick reply to this message
Unread 04-14-2015, 07:02 PM   #2
Benderff
Garage Wheeler
Benderff's Avatar
Use this. http://www.grimmjeeper.com/gears.html
4.56 gears with 33s and the NSG370 transmission are a great combo.
Benderff is offline   Reply With Quote Quick reply to this message
Unread 04-14-2015, 07:39 PM   #3
aw12345
aw12345's Avatar
4.56 and 33's is a happy marriage
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 12:49 PM   #4
bj26pro
Thanks for the input ordered up the 4.56 gears, master install kits and the Ox locker for the front
Unread 04-17-2015, 08:14 PM   #5
Sudcalifornio
the lowest ratio you can go is 4.88, i assume your tj has the d30/d35 combination, they cost the same, you will have more power on the wheels.
Sudcalifornio is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 08:19 PM   #6
DezertTJ
Phrasing
DezertTJ's Avatar
You can go 5.13 now I wouldn't want that for the 2.4 and 6 spd combo though
06 LJ Rubicon: AZ Backcountry LJ Build
DezertTJ is offline   Reply With Quote Quick reply to this message
