2.4L to 4.0L swap questions - JeepForum.com
post #1 of 28 Old 09-14-2011, 07:55 PM Thread Starter
jjeeper
i have a 2003 tj with a blown 2.4L. so I bought a 4.0L out of a 98tj and it came with all the wiring and ECU.
My question is will the wiring from under the dash work properly with the new ECU from the 98? i was told its just gonna be plug-n-play, and would like for someone to confirm this.
thanks
-Jordan
2003 Wrangler SE
jjeeper is offline
post #2 of 28 Old 09-14-2011, 08:10 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
No.
The gauges use different communication systems.
The '98 PCM will not operate the '03 gauges.
Wheelin98TJ is offline
post #3 of 28 Old 09-14-2011, 09:13 PM Thread Starter
jjeeper
great! so now what do i do? find a older gauge cluster?
-Jordan
2003 Wrangler SE
jjeeper is offline
post #4 of 28 Old 09-14-2011, 09:54 PM
Wheelin98TJ
JEEP FREAK
Nah, get a V8.
Autometer gauges should work for you.
post #5 of 28 Old 09-15-2011, 10:20 AM
06pumpkintj
Go with a 4bt swap and keep it a 4banger
06pumpkintj is offline
post #6 of 28 Old 09-15-2011, 11:31 PM Thread Starter
jjeeper
i already have TOO MUCH into the 4.0L to change directions... lol and its been down to long! if this happens to you definitely go V8!
will i be able to make a 97-99 gauge cluster work or do i need to go the autometer route?
-Jordan
2003 Wrangler SE
jjeeper is offline
post #7 of 28 Old 09-15-2011, 11:53 PM
Max-Q
1983 CJ7
Painless makes a wiring harness complete with the ECU and the OBD II port. You just specify the model year and the ECU comes programmed. After that everything should be plug n play. You might check with them and see if their harness will be compatible with your gauge cluster.
It looks like I'm going to get a free 1997 TJ with a 2.5. I plan on swapping it to a 4.6 stroker and using the Painless harness to complete the swap.
1997 Jeep TJ
1983 Jeep CJ7
2011 JK Unlimited Rubicon
Max-Q is offline
post #8 of 28 Old 09-16-2011, 04:05 AM
rda616
I was able to sell my 4.0 and ax15 when I did my v8 swap and wound up with about $600.00 into my 5.9 conversion after parting with the old stuff.
rda616 is offline
post #9 of 28 Old 09-16-2011, 08:22 AM
Wheelin98TJ
JEEP FREAK
The 97-99 gauge cluster will not work.
97-99 uses CCD Bus. Your 2003 uses PCI Bus.
Its not the wiring that is the problem, its the PCM. The 2003 PCM will not drive an older gauge cluster.
Are you sure Painless has that harness? They don't deal with Chrysler stuff too much.
post #10 of 28 Old 09-16-2011, 10:58 AM
Max-Q
1983 CJ7
Yes. It's pricey but it does exist. http://www.4wheelparts.com/Performan...&t_pn=PWP65140
1997 Jeep TJ
1983 Jeep CJ7
Max-Q is offline
post #11 of 28 Old 09-16-2011, 11:25 AM
Wheelin98TJ
JEEP FREAK
Thanks for the link.
Wiring harnesses always seem overpriced, but after hacking together my own, I think they're worth it.
post #12 of 28 Old 09-26-2011, 01:05 PM Thread Starter
jjeeper
ok so let me make sure we are all on the same page.
from the 1998:
-4.0L
-AX15
-under hood wiring
-PCM (grey box by battery)
from the 2003:
-wiring under dash
-gauge cluster
and with this combo my dash will NOT work?
$900+ for the painless wiring is out, so what are my other options?
-Jordan
2003 Wrangler SE
jjeeper is offline
post #13 of 28 Old 09-26-2011, 01:24 PM
Leadsled187
Checl the motor mounts on the frame, i was told they are different from the 2.4 to the 4.0
Leadsled187 is offline
post #14 of 28 Old 09-26-2011, 02:33 PM
Boodyrider
Add move the motor mounts on the frame, and you'll also have to pull the whole 98 underdash harness, use the older gauge panel and probably mix/match a few AC and other underdash type stuff... AND the ABS and antilocks will probably be a huge problem too.
Sell the 4.0 you have and buy one of the correct years with underhood harness and PCM, and hassles get far less. ALL of this info was available here on this forum BEFORE you bought the wrong year 4.0.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #15 of 28 Old 09-26-2011, 02:47 PM
Jeepsr4me
This^^^^^^^
Under the dash is different wiring. I just did what you are doing. But I had a complete set of everything. Only thing that is same under the dash is the connectors for the vacuum lines, A/C heater controls the Air bag and those little lights under the dash and the door button. The rest all different. The gauge cluster will not plug into the harness for the 4.0 that you have. So inside harness and different gauge cluster at the least. Then the welding and cutting of the frame to fit in the 4.0....
Also the gauge you get will show the miles of the ECU that you have. So if more or less it will show.
Jeepsr4me is offline
HP D30 Swap Questions TreeFrog169 TJ Wrangler Technical Forum 2 10-15-2010 02:46 PM
body swap VS motor swap questions baltimorebiker YJ Wrangler Technical Forum 9 03-29-2010 09:49 PM
2.5 to 4.0 swap questions vetteman9368 TJ Wrangler Technical Forum 2 12-15-2009 10:02 AM
4.3L Swap....Questions!!! RabiDaWise YJ Wrangler Technical Forum 6 01-20-2007 11:19 PM
304 swap questions bc yj'er YJ Wrangler Technical Forum 1 11-19-2006 01:03 PM
