2,4, and Reverse Gear popping out of gear. - JeepForum.com
post #1 of 3 Old 08-23-2014, 04:21 PM Thread Starter
gupp91
Manual transmission popping out of gear in 2,4, and reverse. it's an 03 TJ has a 2" body lift 2" coil spacers. I know when i shift into those gears the center console gets moved around by the stick shifter hitting the console. I've read that you can move the console back about an inch by drilling new holes. Any other options or opinions...thanks.
gupp91 is offline
post #2 of 3 Old 08-23-2014, 06:04 PM
hndswthtshdws
Remove body lift
Move console back an inch
Remove shifter boot
Fab a shifter with a different bend in it
You choose. Moving the console is easy.
If you filter out everything that has bad spelling and grammar, you can believe 95% of what you read on the Internet.
hndswthtshdws is offline
post #3 of 3 Old 08-23-2014, 06:33 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X2, get rid of that 2" body lift... they and their even worse 3" body lift cousins are nothing but problems.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
