2.4 to 4.0 swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2.4 to 4.0 swap
End of Summer Sale, 20% OFF!2007 - 2011 Jeep JK Long Arm Lift KitsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-07-2014, 12:16 AM   #1
samuraisavr
2.4 to 4.0 swap
So, after much debate, I'm going to source a 4.0 and manual trans to swap into my 03 tj with a blown up 2.4. I've gone round and round over the whole v8 swap and I just want a dependable OEM solution to my problem. I know MOST of what I need, but my question lies with the wiring. Which years ECMs will swap into the 03s? I know they use a different "language" than the 97-02? but are they year specific? Will I need to change any of the wiring in the dash or should it be a plug and play set up? Provided the engine is correct for 03, a compatible ECM is found, and the dash harness is compatible, this swap should be straight forward. I know I need new frame mounts, 23spline shaft for tcase, a ax15 or nv3550, and I ok with that, but the wiring and ECM thing boggles the mind... Thanks in advance.
Just
Empty
Every
Pocket
samuraisavr is offline   Reply With Quote
Unread 07-07-2014, 12:40 AM   #2
CTM1
Grab everything off a donor vehicle there are so many variances its not worth trying to figure out whats missing.. as u gut out the old stuff you will notice the similarities and differences when you slowily place everything jump in with both feet brother thats why its so tempting to go v8 its about the same minus "engineering cost " ie custim mounts and such
CTM1 is offline   Reply With Quote
Unread 07-07-2014, 02:01 AM   #3
ex m38a1er
How did you blow up your 2.4?
" H TAN , H EΠI TAΣ"
'WHO DARES,WINS'
http://www.jeepforum.com/forum/f37/e...-my-tj-723762/
ex m38a1er is offline   Reply With Quote
Unread 07-07-2014, 02:13 AM   #4
CTM1
Ive had a couple xjs and the smallest little option difference can change a lot its precautionary to do this any swap im planing an ls v8
Unread 07-07-2014, 02:15 AM   #5
CTM1
I did a power window and lock swap to my classic xj dam near had to replace all the wiring some connections change but u have identify as u go along
Unread 07-08-2014, 04:33 AM   #6
danromaine
How bad is the 2.4? I am looking for a block to build. Is it still good?
danromaine is offline   Reply With Quote
Unread 07-17-2014, 10:47 PM   #7
samuraisavr
Block is good, It could likely be rebuilt but I was never impressed by the performance of the 2.4 so I figured I would take the time to make it what I wanted...
Just
Empty
Every
Pocket
Unread 07-19-2014, 04:35 PM   #8
danromaine
What do you plan to do with the motor? If you want to get rid of it how much do you want for it and where are you located? It's hard to find RWD 2.4 blocks around here. Can get FWD versions all day. Thanks, Dan.
Unread 07-21-2014, 07:46 PM   #9
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Read link in my sig. Stick with same year motor. There is a place in Xenia or u-pull on west seymour that will have your motor if you take your time.
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Looking to swap my 4" springs for your 2-3" springs. PM for details.
RnEmOvr is offline   Reply With Quote
