2 1/2" rough country lift? - Page 2 - JeepForum.com
post #16 of 21 Old 03-13-2012, 06:20 PM Thread Starter
PokeTJ
Originally Posted by Unlimited04
adjustable front track bars in front are notorious for hitting the diff cover. The highest clearance track bars available now are JKS and Currie, and both need 2" front bumpstop extensions. For under 3.5" of lift, you're far better off with the stock front track bar, unless you want to run at least 2" of front bumpstop extensions with either a Currie or JKS track bar.
Read this: http://www.jeepforum.com/forum/f9/tj...it-fit-738948/
It looks to me that this is more of a problem if you have a Dana 44
PokeTJ is offline
post #17 of 21 Old 03-13-2012, 06:43 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
no, its a big issue with either the D30 or D44
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #18 of 21 Old 03-13-2012, 07:00 PM Thread Starter
PokeTJ
When I get it in a couple of days, I'll see
PokeTJ is offline
post #19 of 21 Old 03-13-2012, 07:41 PM
Unlimited04
with the springs & jounce bumpers removed, and the shocks & track bar installed, push the axle to full bump (both sides fully compressed at the same time) using a floor jack, and take plenty of detailed pictures.
If you can't get the bumpstop cup to touch the base of the spring/bumpstop pad, you don't have enough bumpstop extension - and you have suspension inteferences.
Useful Write-Ups:
Funny:
post #20 of 21 Old 03-14-2012, 01:24 PM
drewtj05
considering how long the RC 2.5" lift has been out one would think that they would eliminate the bumpstop that they put on the shocks and include a set of bumpstops instead.
drewtj05 is offline
post #21 of 21 Old 03-18-2012, 06:30 PM Thread Starter
PokeTJ
I just finished putting my lift on, it looks like my rough country adj. control arm and bracket clear my front diff. I'll upload pictures later
PokeTJ is offline
2.4 , 2.5 , rough country
2000 TJ w/ Rough Country 4" Lift, 2" Spacers, 35" MT BAJA MTZs roughskinjrz TJ Wrangler Technical Forum 22 02-05-2011 10:10 AM
Rough Country 4" Lift vs. Tuff Country 4" Lift reecep14 TJ Wrangler Technical Forum 3 07-29-2010 02:25 PM
Rough Country 3.25" lift.... flashpoint83 JK Wrangler Technical Forum 24 07-04-2010 03:06 PM
Have a rough country 4" lift with da "gangsta lean" jeepguy85 YJ Wrangler Technical Forum 19 05-25-2010 06:11 AM
Rough Country or Tuff Country 2.5" Lift? bballard1227 YJ Wrangler Technical Forum 7 09-23-2008 06:55 PM
