2 1/2" rough country lift? - JeepForum.com
post #1 of 21 Old 03-01-2012, 05:21 PM Thread Starter
PokeTJ
I'm thinking about getting a 2.5 inch RC lift. Does anybody have anything bad to say about them?
PokeTJ is offline
post #2 of 21 Old 03-01-2012, 05:51 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
A whole lot of people do. If you want a cheap lift go with Zone.
Necromancer_tat is offline
post #3 of 21 Old 03-01-2012, 06:11 PM
nich
My jeep is a daily driver with some offroad. I bought this lift with the upgrade shocks n steering stabilizer and I have been happy. People talk bad about RC but I think they r hard core offroaders I have been thru 30 inches of snow n countless amounts of mud with mine. With my lift and 33 inch swampers I must say it does well. I am changing to duratracs with my taxes but I am a happy camper
nich is offline
post #4 of 21 Old 03-12-2012, 09:46 PM Thread Starter
PokeTJ
Did you every have any driveshaft vibrations?
PokeTJ is offline
post #5 of 21 Old 03-13-2012, 03:26 PM
drewtj05
The RC 2.5" lift is a decent setup but know that there will be parts that you will most likely want to add. First thing I can tell you if you plan on getting this lift is get the springs without the shocks. The 2.2 shocks are rough and tend to leak. Do yourself a favor and get a good set of quality shocks. If you get vibes with the lift do a mml or drop the tcase skid with some washers.
What are you planning on doing with your Jeep? DD, rockcrawling?
drewtj05 is offline
post #6 of 21 Old 03-13-2012, 03:41 PM
aoh1811
Just did the RC 2.5" so far so good, I hope they don't leak!
“Cannons don't thunder, there's nothing to plunder, I'm an over 40 victim of fate"
aoh1811 is offline
post #7 of 21 Old 03-13-2012, 03:45 PM
aoh1811
Where exactly do you put the washers on the transfer skid? It doesn't look like anything is close to hitting on mine?
aoh1811 is offline
post #8 of 21 Old 03-13-2012, 04:28 PM
Mortalis5509
If you need washers they go between the skid plate and the frame to help reduce drive line vibration.
RC coil springs and shocks are not bad. If you are the orginal purchaser then it's a lifetime warranty if something were to happen to them. It's a softer ride but not that bad. The "kit" does not come with bump stops so that is something that you will need to add. Use hockey pucks as they are cheap and do the job well.
Go DAWGS
Mortalis5509 is offline
post #9 of 21 Old 03-13-2012, 04:38 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
they leak because they bottom out a lot. they bottom out a lot because RC doesn't give you the necessary bumpstop extensions to prevent them from doing so.
determine the compressed length of the shocks front and rear, and add bumpstop extensions accordingly.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #10 of 21 Old 03-13-2012, 04:40 PM
PurpleTJ
I got this lift about two and a half years ago. It was fine at first, improved my ride quality a bit, but now its saggy and rough. Over that time I daily drove it probably 15k miles, wheeling about once a month.
Now I have Currie 3" springs sitting in the garage, and Fox shocks from Savvy are very next on the list
Purple Jeep Club member #8
PurpleTJ is offline
post #11 of 21 Old 03-13-2012, 05:00 PM
drewtj05
x2 on the bumpstop extensions, but as far as the shocks a lot of people myself included did not have a good experience with the 2.2 shocks. I did read in another thread that a guy bought the N2.0 shocks for the 4" lift and is running them with no problems on the 2.5" RC springs. Think he got them for not too expensive. Personally though I would invest in some bilstein shocks just my
drewtj05 is offline
post #12 of 21 Old 03-13-2012, 05:04 PM
Unlimited04
this makes no sense. you can't just run 4" lift shocks on a 2.5" lift, the shocks will be too long and the bottoming out will be much worse.
Useful Write-Ups:
Funny:
post #13 of 21 Old 03-13-2012, 05:47 PM Thread Starter
PokeTJ
I ordered it yesterday without shocks and a adjustable front track bar and rear track bar bracket
PokeTJ is offline
post #14 of 21 Old 03-13-2012, 05:57 PM
Unlimited04
adjustable front track bars in front are notorious for hitting the diff cover. The highest clearance track bars available now are JKS and Currie, and both need 2" front bumpstop extensions. For under 3.5" of lift, you're far better off with the stock front track bar, unless you want to run at least 2" of front bumpstop extensions with either a Currie or JKS track bar.
Read this: http://www.jeepforum.com/forum/f9/tj...it-fit-738948/
Useful Write-Ups:
Funny:
post #15 of 21 Old 03-13-2012, 06:15 PM
drewtj05
I am not saying it is logical, just saw that he is running them.
I just reread the thread it says he is running the N20 shocks on the 2.5" spring with the 3/4" spacer. I thought it was odd because it is a shock that is 26 Front Extended and 15" collapsed and the rears are 14 collapsed and 24 extended. Here is a link to the thread. http://www.jeepforum.com/forum/f9/ne...1/index18.html
drewtj05 is offline
2.4 , 2.5 , rough country
2000 TJ w/ Rough Country 4" Lift, 2" Spacers, 35" MT BAJA MTZs roughskinjrz TJ Wrangler Technical Forum 22 02-05-2011 10:10 AM
Rough Country 4" Lift vs. Tuff Country 4" Lift reecep14 TJ Wrangler Technical Forum 3 07-29-2010 02:25 PM
Rough Country 3.25" lift.... flashpoint83 JK Wrangler Technical Forum 24 07-04-2010 03:06 PM
Have a rough country 4" lift with da "gangsta lean" jeepguy85 YJ Wrangler Technical Forum 19 05-25-2010 06:11 AM
Rough Country or Tuff Country 2.5" Lift? bballard1227 YJ Wrangler Technical Forum 7 09-23-2008 06:55 PM
