1st time jeep owner w/dumb question (: - JeepForum.com
post #1 of 17 Old 07-30-2006, 02:52 PM Thread Starter
BamaJeepGirl
hi,
i've had my tj for about a week, it didn't come with an owners manual
how do i remove the hardtop? after i open the two latches does the front of the top lift up or slide back? what kind of tool is needed to remove the bolts in the back of the top? can someone email the instruction to remove the hardtop or can i download them from a web site? checking ebay now for a used manual.......sigh
BamaJeepGirl is offline
post #2 of 17 Old 07-30-2006, 02:54 PM
thejafe
thejafe's Avatar
You need a TORX set. Torx bolts are all over the Jeep and are what secure the hard top in the rear. Once you take the front latches off, remove the Torx bolts and the top lifts up and off the Jeep .
thejafe is offline
post #3 of 17 Old 07-30-2006, 02:55 PM
stevensinger
stevensinger's Avatar
you need to undo the screws on the sides of the body in the back, welcome to the forum please remember to use the search tool it will answer 90% of your questions...
stevensinger is offline
post #4 of 17 Old 07-30-2006, 02:56 PM
Forumpete58
Unlatch the two front latches, unscrew the six torx bolts around the sides (under the rear windows), unhook the electrical hookup for the window defrost and hose for washer fluid, finally find a buddy to help you lift it off. It can be done by yourself but many don't recommend it. Have fun topless!!
Forumpete58 is offline
post #5 of 17 Old 07-30-2006, 02:59 PM
REDPILL
REDPILL's Avatar
Originally Posted by BamaJeepGirl
hi,
I'll be the first to say WELCOME!!!!!!!!
Don't forget to
jclaude
Originally Posted by JeepGirl04 View Post
when it doubt... pull it out
Matthew 6, 5-6 Read it, Follow it.
2004 unlimited Yellow
REDPILL is offline
post #6 of 17 Old 07-30-2006, 03:01 PM
silver97tj
silver97tj's Avatar
welcome.....check your pm's.........................
ps pm is private mail, messages............
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
post #7 of 17 Old 07-30-2006, 03:03 PM
newbs
Jeepaholic
if I recall it's a torx 40 I should remember I just did 20 minutes ago and there are 3 on the right side and 3 on the left side you have to undo and the top may be stuck to the body so you may have to wiggle to break it loose and pick it up and slide it off useing 2 people
newbs is offline
post #8 of 17 Old 07-30-2006, 03:13 PM
jeffwen02
with the first two in the front near the doors, you gotta make sure you reach your finger up in there and hold that piece when you take the top bolt off, because once that metal piece falls into the frame say goodbye to that piece. just take it slow, it's easier than it sounds
i'm mechanically retarded, so... it shouldnt be too hard for you
2005 black rubicon. x < 1000 miles as of now
jeffwen02 is offline
post #9 of 17 Old 07-30-2006, 03:19 PM
Oman Jeep
Oman Jeep's Avatar
Just remember that you'll want some help getting it off. That thing is pretty damn heavy, you'll probably need at least one strong friend... two if you're a slim build.
Oman Jeep is offline
post #10 of 17 Old 07-30-2006, 03:48 PM
thesherm
thesherm's Avatar
also, as obvious as it sounds, you want to make sure you have a spot laid out for the top before you take it off. i use some 2x8s with carpet remnants stapled to it to protect the fiberglass edges. watch out for the rear glass which may pop open unexpectedly when you lift the top.
98 Sahara
Originally Posted by mrblaine
Unfortunately you are one of those poor misguided folks that believes leaving the gear shift lever in one slot or another is an indication of control.
Come go for a ride and I'll be glad to demonstrate the difference between what you perceive incorrectly as "control" and what control actually is.
Pick a different reason because that one is both lame and stupid to perpetuate.
Pardon me for damaging your precious reputation. It's not that I disagree, that would be a difference of opinion. This isn't subjective, it's objective, you are just wrong. If you make that statement, you are misguided. It is that simple.
thesherm is offline
post #11 of 17 Old 07-30-2006, 04:03 PM
02tjsport
2014 KL Cherokee
wooden picnic table works perfectly....lift up back glass and straddle the table and sit hte sides of hte top on the benches of the table.
02tjsport is offline
post #12 of 17 Old 07-30-2006, 07:32 PM
jeep-n00b
Where are you at in AL? I'll be heading down to the Dothan/Enterprise area at the end of September. Are there any good trails down there?
jeep-n00b is offline
post #13 of 17 Old 07-30-2006, 10:44 PM Thread Starter
BamaJeepGirl
madison. i'm new to jeeps so i don't know anything about trails or 4 wheeling, yet....i hope to learn soon i'm trying to find a local jeep club to join.
thanks everyone for your advice and instructions
i'll make sure i get help from a male friend or two before i try and remove the hardtop, i know i can't remove it alone it looks heavy.
post #14 of 17 Old 07-31-2006, 06:49 AM
cupharmboy
So I pick up my Sahara today and the soft top is on it at the moment. I get his hardtop also so do I need to ask for the tool that came with it? Or will it be just as easy to just go buy a Torx 40? Cost?
PS> Sorry for the Hijack!
cupharmboy is offline
post #15 of 17 Old 07-31-2006, 07:14 AM
jeepin_man
it is just a bit, you should be able to find one pretty cheap.
jeepin_man is offline
here is my jeep! 1st time yj owner. hartmen Wrangler General Discussion 10 10-11-2009 07:33 PM
1st time Jeep owner Slenny JK Wrangler Technical Forum 3 07-29-2007 10:21 AM
First Time Jeep Owner Here BuddhamanJB TJ Wrangler Technical Forum 4 07-25-2007 09:01 AM
about to be a first time jeep owner ryan188 TJ Wrangler Technical Forum 20 09-25-2006 08:54 PM
time for a dumb question muddyforeman TJ Wrangler Technical Forum 7 10-21-2005 08:31 PM
