Quantcast 1999 Wrangler starting problems. Ths clicking will haunt me forever. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 1999 Wrangler starting problems. Ths clicking will haunt me forever.
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 05-14-2008, 03:14 PM   #1
HoosierDaddyTJ
I just bought my first Jeep a few months ago (1999 Wrangler Sport) so today when it wouldn't start I didn't mind putting some money into it. With a new starter, starter relay, and battery it still makes some clicking sound machine gun style instead of cranking over. Could it be the neutral throw-out safety switch? Do Jeeps have those? Am I on a bad spot on the fly-wheel with the starter gears? Help me please, I'm going nuts.
Anything worth doing is worth doing right.
I wave at other Jeeps and get my feelings hurt if they don't wave back.
99 TJ 4.0L ALL BLACK, 2 in RE BB and 32X10.50 Super Swamper TSL Radials
HoosierDaddyTJ is offline   Reply With Quote
Old 05-14-2008, 03:20 PM   #2
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Battery cables and connections good?
Even if the clamps on the ends of the cables look good, I'd still take a second and clean them up with sandpaper or a file.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 05-14-2008, 03:28 PM   #3
HoosierDaddyTJ
Yah, They're good. Along with all fuses and other connectors. I cleaned up the ends. I haven't checked the whole wiring system top to bottom yet. I wasn't about to remove the wire covering, that black plastic that's around everything. It's there for a reason and I don't want to replace it for no reason. I'll remove it when it's absolutely necessary.
Old 05-14-2008, 05:08 PM   #4
HoosierDaddyTJ
I got it!
I guess the new starter gears were either in a bad spot on the fly wheel or jammed up on the gears because all I did was put it in gear and shove it a couple of times (thanks to a suggestion from my Dad) and it fired right up. Crazy thing I guess. Thanks for the help.
Glock Forum
