1999 TJ - Pulsing Interior & Exterior Lights - JeepForum.com
post #1 of 6 Old 01-24-2013, 11:18 AM Thread Starter
jademarzo
Hello Fellow Jeepsters,
I have searched the forums for an answer to an issue I've been having in my Jeep for the last 2 weeks or so. I've found some good information, but most problems others have been facing are not exactly the same as mine.
Jeep: 1999 Jeep Wrangler - Sport, I6, manual trans
When I sit at idle, the lights flicker, and the voltage meter goes from a 14 down to a 12, then goes red. Sometimes it jumps back on its own, sometimes not. As soon as I put it in first and start driving, the voltage meter runs back up to 14 and the light in the exterior and interior get brighter.
While I'm driving on the freeway, the light will also flicker even though I'm not changing speeds or gears. Sometimes they will get brighter as I push the gas, and get dimmer as I ease off the gas.
Does anyone have any ideas what this problem can be?
I know that it could be: Alternator / Voltage Regulator / Bad Ground...
But not really sure which of those it is most likely. Anyone have this problem before? Any clues on things to check to get a better diagnosis?
I really appreciate the time and everyone's responses.
Have a great day.
John
jademarzo is offline
post #2 of 6 Old 01-24-2013, 02:34 PM
WahooCreek
Could also be battery issue.
WahooCreek is offline
post #3 of 6 Old 01-24-2013, 07:18 PM
MarkR_98Sport
2014 JK Wrangler
Do you have any aftermarket electronics? Have there been any mods to the electrical system other than plug and play component? How old is the battery? Alternator? How long has the issue been going on?
MarkR_98Sport is offline
post #4 of 6 Old 01-25-2013, 05:08 PM
bigrob713
Start with the obvious first. Check your belt and belt tension.
bigrob713 is offline
post #5 of 6 Old 02-06-2013, 03:13 PM Thread Starter
jademarzo
Only the radio. Battery is 1 year old, not sure about alternator though.
I will check out the forums and see if there is any info on it. Thank you for the response. I'll update when I figure more out.
post #6 of 6 Old 09-18-2014, 02:12 PM
JWebber
Bad ground somewhere, check all ground wires and check the end connections. clean all your battery connections as well.
JWebber is offline
lights , pulsing , tj , wrangler
