1999 Jeep Wrangler Heat Not Working - JeepForum.com
post #1 of 18 Old 11-11-2010, 11:47 AM Thread Starter
albatross0929
I am an original owner of a 1999 Jeep Wrangler manual 6 cylinder. It has about 65,000 miles on it. The heat is not working at all. The blower is working, but it is just blowing out cold air. The air conditioning has been working fine. I replaced the radiator a couple of years ago, but no major work has been done on it since (except regular maintenance). Nothing is leaking anywhere. Do I need a new heater core?
albatross0929 is offline
post #2 of 18 Old 11-11-2010, 12:37 PM
Craft95ZJ
1986 MJ Comanche
did you check the thermostat?
Daily driver '01 TJ 3" RC lift
'86 MJ 3.4L interior rebuild in progress.
Craft95ZJ is offline
post #3 of 18 Old 11-11-2010, 12:43 PM
joes924
The heater core is probably plugged. Soak and flush it with CLR! Only use CLR in the core to flush not the whole system!
Ain't no sence in bein stupid unless you show it off!
joes924 is offline
post #4 of 18 Old 11-11-2010, 12:58 PM
drewkjeldsen
I had the exact same problem last year on my 2000 tj. Would just blow cool air, room temp at best with the heat on. Ended up needing the thermostat replaced. Pretty cheap part, and very easy to do yourself.
drewkjeldsen is offline
post #5 of 18 Old 11-11-2010, 01:00 PM
IslandTJ
Check your blend door as well...
Now Jeeping in Oregon
IslandTJ is offline
post #6 of 18 Old 12-27-2010, 09:59 AM
jeeper70
99 wrangler heater not cooling
I am having the same problem. Was the thermostat bad? If so, is there a particular brand of thermostat that is better than the others?
jeeper70 is offline
post #7 of 18 Old 01-03-2011, 07:39 PM
Mahanoy
Where would you get the blend door motor and the temp switch inside cab
Mahanoy is offline
post #8 of 18 Old 01-03-2011, 08:10 PM
2GPS4ME
Nothing is leaking, but have you taken the radiator cap off and ensured the radiator is full of coolant?
Narrow Road Jeep Garage
Owner, Operator
2GPS4ME is offline
post #9 of 18 Old 01-05-2011, 07:32 PM
PJM
Hi Folks,
I am having the same problem. Never any coolant smell or leaks on the passenger carpet.
So today I drained the radiator (I was embarrassed how little fluid was in there).....probably only about a gallon of more brown water than coolant.
I flushed it with the heater on full blast for about 15/20 minutes.....no heat. then drained it again then took out the thermostat (It almost seemed like it was dry and a rusty brown. After that I refilled the rad with 50/50 and ran it again....
Still no heat but no puddles or maple syrup smells though. I noticed while I was repackaging the old water and flushings that there was a lot of sediment in the bottom of the bucket.
Something is probably clogged any ideas where I can go from here.
BTW, how would I go about flushing the heater core with CLR?
Thanks,
Pat
PJM is offline
post #10 of 18 Old 01-05-2011, 07:39 PM
sduncan
sduncan's Avatar
A buddy had this problem last year..I told him to disconnect the heater hoses and take a water hose and simply flush the core. He got all kinds of crap out of it flushing it both directions. Heater works like a champ now...
'98 TJ, 5.7 HEMI,
sduncan is offline
post #11 of 18 Old 01-05-2011, 08:23 PM
PJM
Alright after a couple of youtubes and threads on this great site I have a mental picture of how to flush the heater core with the hose. I am still a little confused how to keep the CLR in the core while it works its magic? I would guess that I would disconnect the hose at the rad side and not the firewall....and send it tdown the tube and let sit a while.....
Another dumb question.....should I have the heater running while flushing....or does it matter?
Pat
PJM is offline
post #12 of 18 Old 01-05-2011, 08:33 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Pat
Nope...
Knuckelhead is offline
post #13 of 18 Old 10-28-2011, 05:49 AM
Bilicki2007
Does the CLR fix the problem over using radiator flush in the heater core?
Bilicki2007 is offline
post #14 of 18 Old 10-28-2011, 06:42 AM
JBTJ
Do NOT use CLR!!! Read the back of the bottle!!! It's not safe to use. It will eat up the aluminum in the heater core. You will do better using vinegar or the stuff made by Preston to do the cleaning. Then dont use tap water when you refill. That causes the heater core to clog up.
JBTJ is offline
post #15 of 18 Old 10-28-2011, 06:44 AM
Bilicki2007
I tried using Vinegar before, and it didn't seem to do the trick. Still blows cold, and bottom hose is considerably cooler than the top hose
Is a 1999 Jeep Cherokee 2.5L 4 cyl a direct replacement into a 1999 Wrangler 2.5L 4cy smilesssss TJ Wrangler Technical Forum 0 08-20-2009 08:09 PM
1999 Jeep wrangler shocks POTBSS TJ Wrangler Technical Forum 2 07-14-2009 08:48 PM
1999 Jeep Wrangler Hesatation 2.5L 1954Dodge TJ Wrangler Technical Forum 1 09-25-2008 09:46 PM
Will a 2006 stock radio from a jeep wrangler fit a 1999 jeep wrangler 1954Dodge TJ Wrangler Technical Forum 2 08-16-2008 09:40 AM
1999 Sahara Jeep Wrangler M60-E4 TJ Wrangler Technical Forum 22 06-05-2006 09:33 PM
