1999 4.0 TJ pulling to the left - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 1999 4.0 TJ pulling to the left
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!The Original 3/8" Ruffstuff Diff Cover!
Unread 06-25-2015, 03:08 PM   #1
Cleggmeister
Greetings folks,
An annoying fault with my newly acquired 4.0 TJ Sport... It pulls left on a flat road. Enough to annoy though not enough to be a danger. I've had an alignment check which improved things slightly however the issue remains. If I boot it the Jeep pulls left more strongly for a moment, and if I brake hard it seems to straighten momentarily. Subtly though, so I might be talking bs...
Any thoughts on diagnosis gladly received. The Jeep is stock and has covered 36,000 miles. Tyre pressures are fine, no brakes binding. Recently had new control arms and a new steering stabiliser. My steering wheel is slightly off centre if any of that is relevant?
Many thanks.
Cleggy.
Cleggmeister is offline   Reply With Quote Quick reply to this message
Unread 06-25-2015, 04:34 PM   #2
JFM626
Odly enough, your problem may be in the rear suspension, one of the bushings could be worn, to the point that under hard throttle the rear axle shifts a little and steers the jeep. When you brake the braking action pulls the axle back into allignment and the jeep goes straight. Could be as simple as loose bolts having oblonged a hole. Maybe worth a decco?
How can you trust an atom, they make up everything
JFM626 is offline   Reply With Quote Quick reply to this message
Unread 06-25-2015, 04:46 PM   #3
1orangews6
If the alignment was done then the steering wheel shouldn't be off center. The pulling could be caused by several things such as the crown in road, uneven air pressure an under inflated tire also has more rolling resistance causing to pull, and uneven tread wear could cause it to pull.
2006 LJ Silver / 2013 Trail Hawk Silver stock / 2001 Sunset Orange WS6 heavily modified
1orangews6 is offline   Reply With Quote Quick reply to this message
Unread 06-25-2015, 05:53 PM   #4
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Align it yourself. Also check for sticking brake caliper.
http://www.stu-offroad.com/steering/align/align-1.htm
RnEmOvr is offline   Reply With Quote Quick reply to this message
Unread 06-25-2015, 07:27 PM   #5
JFM626
Speaking to the crown of the road aspect of your reply only. He is driving in Scotland, where everyone drives on the left, so yes if his Jeep came from overhere and is a left hand drive, then the steering and axle geometry would be set for a crown in the road over here. Over in Scotland, it would certainly pull to the left, off the crown of the road and onto the shoulder of the road
Unread 06-25-2015, 09:19 PM   #6
1orangews6
Everything in my post could cause a vehicle to pull in a direction.
Unread 06-26-2015, 04:57 AM   #7
Cleggmeister
Thanks folks, I'm leaning towards (pardon the pun) something loose/worn in the rear suspension/geometry. Will get it on stands over the weekend and look for wobbles.
I'll straighten the steering wheel myself - it was a job I performed on my JK a few years ago and (I guess) is the same for a TJ? Not sure why they didn't sort that when aligning the wheels...
1999 TJ Sport, 4.0, restoring to former glory before I begin with the mods.
Unread 06-26-2015, 05:39 AM   #8
1orangews6
If you paid for the alignment already I would take it back and have them fix it. Most places here have a 6,000/6 month mileage warranty on their alignments.
