1998 wrangler sputters and cuts out - JeepForum.com
post #1 of 12 Old 03-04-2011, 09:25 PM Thread Starter
alexjfrench
The problem I am having is when I start the jeep cold it starts and runs great, when I then shut it off and come back to it 20 minutes or so later and it is still warm and start it, it starts fine but when I put it in gear and go to drive away it starts to sputter and stall it wont shut off but close. However if i push down on the gas and get up to like 20 mile per hour it will quit and not do it again its fine after that. It does it really bad if you are just barley pushing on the gas if you floor it, it gets past it real quick and is fine. It is a 98 wrangler automatic and 4.0 no check engine light is on and there is no codes. I have read a bunch and a lot of people are having problems with the upstream o2 sensor and possibly a leaky injector does anyone have any thoughts thanks.
alexjfrench is offline
post #2 of 12 Old 03-05-2011, 07:51 AM
1fastR
1fastR's Avatar
How many miles on it? Any recent work/tune ups done to it?
1fastR is offline
post #3 of 12 Old 03-05-2011, 11:16 AM Thread Starter
alexjfrench
148000 i am not sure what has been done to it i just bought it as is. It looks as though the plugs and wires and cap have been replaced along with a exhaust manifold gasket.
post #4 of 12 Old 03-08-2011, 05:47 PM
1fastR
1fastR's Avatar
My initial thought was/is O2 sensor but not positive.
Bump for you, maybe someone else will have some input.
1fastR is offline
post #5 of 12 Old 03-31-2012, 09:34 PM
cori131
i'm having the same exact problem with my Jeep, did you ever find out what was wrong with it?
cori131 is offline
post #6 of 12 Old 07-12-2012, 06:35 PM
Wrangles
Same issue
Folks, I have same issue. My jeep is 98, v6, and has 118k miles. I have done full tune up, fuel injector flushing, changing o2 sensor and still sputtering. Also accelerates on its own at times.
Any thoughts?
Wrangles is offline
post #7 of 12 Old 07-12-2012, 06:42 PM
TJ-Tera
Any thoughts?
VEE 6? You mean inline 6?
TJ-Tera is offline
post #8 of 12 Old 07-12-2012, 06:55 PM
noise_maker
mine used to do that. Would start up fine but would be stupid when you stopped - real bad if you had been on the highway for 15 mins. Took me awhile to figure mine out - the temp guage never went above 215 either but replaced the thermostat and changed the coolant and the problem went away.
noise_maker is offline
post #9 of 12 Old 07-12-2012, 07:06 PM
HOOKEM1
Mines 05 w/64000 surges bad @ start up till warms I thought might b injector prob or O2 sensor but seeing your post bout changing temp gauge I'll rethink it cuz mine runs bout 210 I just flushed an changes coolant put in Lucas fuel treatment for injectors running worse now. Any thoughts
HOOKEM1 is offline
post #10 of 12 Old 05-20-2013, 01:04 AM
jeeper4lifeTj
Does your RPM spike when you are having this problem
jeeper4lifeTj is offline
post #11 of 12 Old 05-20-2013, 01:11 AM
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
Holy Thread Ressurection, Batman!
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig:
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline
post #12 of 12 Old 05-20-2013, 01:28 AM
jeeper4lifeTj
Yeah i know,
I had a similar problem FOR YEARS but my RPM's would spike.
It had all those codes too and I changed them all.
They worked for a while, then the problem would come back.
Then one day my oldtimer neighbor heard my misfire and came over.
Point is... He disconnected my crankshaft sensor and cleaned it, then he tightens up the end that connects to my transmission.
I HAVEN'T HAD THE PROBLEM SINCE
2.5 sputters and cuts off after start up cranberry33 YJ Wrangler Technical Forum 3 06-27-2008 04:39 PM
87 wrangler that aceleration cuts out jeeper87 YJ Wrangler Technical Forum 3 06-20-2007 12:48 AM
1998 Wrangler Sport Value ? mknherhappy TJ Wrangler Technical Forum 7 06-02-2006 05:08 PM
1998 wrangler sport tommy4902 TJ Wrangler Technical Forum 12 07-20-2005 11:16 AM
Using a Soft-Top From a 2000 Wrangler on a 1998 Wrangler? Nighthawk TJ Wrangler Technical Forum 3 06-05-2002 05:02 PM
