1998 wrangler sport vs. 2000 wrangler sport - JeepForum.com
post #1 of 16 Old 02-12-2007, 08:57 PM Thread Starter
David Hinton
what is the differences between a 2000 wrangler and a 1998 wrangler in:
1) cosmetics
2) engine
3) transmission
4) smog crap that dramatically affects mpg??
so is the 2000 year model basically the same (performance and mpg) as 1997-1998 jeep wranglers?
Thank you guys so much!!!!
David Hinton is offline
post #2 of 16 Old 02-12-2007, 08:59 PM
Rocky529
Rocky529's Avatar
1998
Chrylser becomes Daimler/Chrylser
New Exterior Colors:
Chili Pepper Red Pearlcoat
Deep Amethyst Pearlcoat
Smart Key Immobilizer replaces previous Lock/Unlock keyfob system.
Cruise control Available
Ez-Entry Driver's seat now available
Revised torsion bar for improved steering response
Revised steering gear ratio that varies from 15:1 on centre to 13:1 at the extremes of travel for more responsive steering
New steering wheel
Next generation airbags
Revised stereo range
Hood latch changes
3.73 ratio rears and Dana 44 Rear
New engine managment system wiring
Dual Tops Option
Added pads to front bumper -- front license plate moved to the center of the bumper
30" tire package came with the "Gambler" style wheels (15x8).
Late Model:
Defeat switch for passenger-side air bag
2000
Solar Yellow
Patriot Blue Pearlcoat
Silver Stone
Discontinued Exterior Colors:
Chilli Pepper Red,
Gunmetal Blue
Intense Blue
Deep Amethyst.
Alternator moved higher up
Ultra Star 16" alloy wheel now standard on Sahara models.
4.0L engine now gets distributorless direct-ignition system, re-designed cylinder head, new exhaust manifold and dual-catalyst system (2.25" exhaust)
New NVG-3550 manual transmission replaces the Aisin transmission on the models with the 4.0L engine (includes synchromesh on reverse gear).
Sound Bar now standard on Sport models.
Tow hook option now includes one rear tow hook.
Sport's standard AM/FM radio adds a cassette player, Sahara exchanges a cassette player for CD player.
Optional tilt steering wheel in SE and Sport is now the same leather-covered unit that was standard in Sahara.
Child-seat tethers added to the rear seat,
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 16 Old 02-12-2007, 09:06 PM
SecondTJ
SecondTJ's Avatar
The 2000 would be a much better choice.
As it got a power boost, (190 hp, 235 lb-ft from 181 and 222) from what Rocky showed above- distributorless ignition is the big one. Also, in 99, there was a redesigned intake manifold
Plus you get the NV3550 over the AX-15
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #4 of 16 Old 02-12-2007, 09:23 PM Thread Starter
David Hinton
well, yea but the 1998 had far less smog detactors which allowed the 1997-1998 to be more powerful and higher mpg, i talked to a couple guys and they said their 1997's got 17+ lifted with 33's.
With the new cylinder head, didnt that make things alot worse, (MPG, power??) or did that not start tell 2001?
Thanks alot tho!!
post #5 of 16 Old 02-12-2007, 09:34 PM Thread Starter
David Hinton
? (prevous response)
post #6 of 16 Old 02-12-2007, 09:50 PM
SecondTJ
SecondTJ's Avatar
The 97-98 weren't more powerful.
as i said:
97-99 had 181 hp and 222 lb-ft of torque.
00+ had 190 hp, and 235 lb-ft.
no, the new cylinder head didn't make things worse. The biggest gain was to be found in the new intake manifold though.
My 2000 window sticker said 16/19 for gas mileage. I get 17-18 mpg on 31s with 3.73 and the NV3550
Getting 17mpg on 33s has more to do with gearing and transmission and driving style than minor engine changes
SecondTJ is offline
post #7 of 16 Old 02-12-2007, 09:54 PM Thread Starter
David Hinton
ok thanks,
post #8 of 16 Old 02-13-2007, 08:36 AM Thread Starter
David Hinton
but does the 2000 model have as much or the same smog regulations as a 98?
post #9 of 16 Old 02-13-2007, 10:13 AM
SecondTJ
SecondTJ's Avatar
your worrying about all the wrong things, lol.
the only difference, if any. is that the 2000 might have pre-cats that the '98 doesn't. But pre-cats are only useful on cold start-ups to reduce emissions before the main cat warms up, after its warmed up, the pre-cats are useless.
SecondTJ is offline
post #10 of 16 Old 02-13-2007, 12:59 PM Thread Starter
David Hinton
sweet thanks, and i can just get rid of those pre-cats with like a flowmaster or what ever right? Or would that not pass emmission testings?
post #11 of 16 Old 02-13-2007, 01:12 PM
mdm
Farm Wheeler
The earlier TJs had exhaust manifolds that are prone to cracks. The manifold was changed in 2000 and is less likely to crack.
mdm is offline
post #12 of 16 Old 02-13-2007, 06:45 PM Thread Starter
David Hinton
thanks, that was a repeat
post #13 of 16 Old 02-13-2007, 09:40 PM
Rule303
Very minor differences between those years. Just buy the best vehicle if that's why you are asking.
Rule303 is offline
post #14 of 16 Old 02-13-2007, 09:59 PM
SecondTJ
SecondTJ's Avatar
Cosmetic/package wise yea, but drive train wise there were quite a few important differences.
SecondTJ is offline
post #15 of 16 Old 02-13-2007, 10:24 PM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
My favorite part of the 2000 was the distributorless ignition and redesigned intake. You can't just swap the ignition but I did nab a 2K intake manifold. Bolted right up.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
1998 Wrangler Sport: Blinkers Not Working BMoe Wrangler General Discussion 4 01-06-2009 03:34 PM
How do I remove radio from 1998 wrangler sport yawnocmot Wrangler General Discussion 1 07-18-2008 07:42 PM
cigarette lighter on 1998 Wrangler Sport hassenpfeffer TJ Wrangler Technical Forum 11 08-13-2007 01:43 PM
1998 Wrangler Sport Value ? mknherhappy TJ Wrangler Technical Forum 7 06-02-2006 05:08 PM
1998 wrangler sport tommy4902 TJ Wrangler Technical Forum 12 07-20-2005 11:16 AM
