1998 Wrangler Sahara Edition with Automatic transmission pan leak. Second time of major leak in 6 months. Changed gasket and pan on first leak, stopped leak till now. Both leaks were towards the motor side of the pan. Any suggestion would be awesome.
You should also check to make sure that the pan bolts weren't over tightened causing the bolt hole area to crush in, which would limit how well the pan actually contacts the transmission. My transmission pan had that exact issue, and I had to use a hammer to flatten them back out. It sealed right up after that.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
