1998 Wrangler Passenger Seat Lift - JeepForum.com
post #1 of 4 Old 11-20-2006, 08:57 AM Thread Starter
owensdw
My
Passenger Seat will no longer recline foward to allow passengers in and out.
Is this a common problem, with an easy fix?
Thanks
Donnie
owensdw is offline
post #2 of 4 Old 11-20-2006, 09:25 AM
jeepskinc
jeepskinc's Avatar
This needs to be moved over to the TJ forum.
I assume by recline forward you are no longer able to lift the up on the small latch on the lower back of the seat causing the seat to tilt forward for easier access to the back. My 97 TJ has the same problem. From what I can tell the cable that runs from the latch to the release mechanism below the seat is no longer providing enough tension to release the mechanism. I have not tried fixing yet. You can reach down from the front and release the mechansm but its a pain. If someone knows a fix for this, I'd like to hear it.
jeepskinc is offline
post #3 of 4 Old 11-20-2006, 10:10 AM
rpg1520
Heavily Armed Liberal
Mine doesn't work either, but I can always get it to tilt up, l hope I can explain this. I just hold the seat slider lever up with my right hand and push the seat foward with my left hand, it just tilts right up. Must be a 97 thing.
rpg1520 is offline
post #4 of 4 Old 11-20-2006, 10:40 AM
erickpl
erickpl's Avatar
Maybe the pull cable is broken?
http://www.4x4xplor.com/seattrack.html
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
Swapping Drivers seat for passenger seat trevsbmw YJ Wrangler Technical Forum 8 05-22-2009 05:38 PM
Passenger Seat nix_toy JK Wrangler Technical Forum 14 05-30-2007 09:21 PM
Help with the passenger seat. Pomlovers2 TJ Wrangler Technical Forum 11 04-29-2006 11:26 PM
passenger seat desmo TJ Wrangler Technical Forum 21 03-11-2005 10:02 PM
Passenger seat tallgirl TJ Wrangler Technical Forum 2 11-13-2004 02:08 PM
