1998 WRANGLER front seat removal [passenger] is a *****! - JeepForum.com
post #1 of 40 Old 07-21-2012, 04:02 PM Thread Starter
hepme70
Opps, is that allowed?
Anyway, I have the two front bolts removed; I then thought, "this is simple."
WRONG! Evidence--if I 'm lucky enough to find some--points to the odd fact that the other two bolts are located underneath. Wow, not a good thing!
I'm going back out later and will again tackle this bi...! Help, if you know something I don't?
hepme70 is offline
post #2 of 40 Old 07-21-2012, 04:09 PM
trez
You can't possibly be confused. Right tight left loose
if the door is open close it, kick it down and make a kramer style entrance
trez is offline
post #3 of 40 Old 07-21-2012, 04:11 PM
Vinman
Uhhh, slide the seat all the way forward, lift the 2 plastic bolt covers and remove the bolts.
One of the bolts is a torx.
Vince
Vinman is offline
post #4 of 40 Old 07-21-2012, 04:36 PM
NEI10
ALL the bolts are visible and accessible from the top/inside the cab, not underneath. and yes, one (on each side) is a torx.
2013 10th Anniversary Edition Rubicon
Jan/Feb '06 JP Magazine Cover
NEI10 is offline
post #5 of 40 Old 07-21-2012, 07:25 PM Thread Starter
hepme70
Thanks men, I back on the job but I will have to buy some * tools.
Hey, I never said I was a mechanical genius.
hepme70 is offline
post #6 of 40 Old 07-21-2012, 08:02 PM
silver97tj
silver97tj's Avatar
Hi all
I have the same year jeep, torx is a pain but 8 minutes tops and there out. make sure you antisieze them when they go back............................
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
post #7 of 40 Old 07-21-2012, 08:07 PM Thread Starter
hepme70
Originally Posted by silver97tj View Post
Hi all
Wow! I see a 1/4 inch play to work with on those well hidden torx heads. What kind of tool will work well with that ridiculous clearance?
What do you mean by antisieze them?
hepme70 is offline
post #8 of 40 Old 07-21-2012, 08:16 PM
Benderff
Benderff's Avatar
Move the seat forward.....
Benderff is offline
post #9 of 40 Old 07-21-2012, 09:09 PM
wushaw
Rockin jeep
wushaw's Avatar
Put anti seize compound on the threads so if you ever have to remove them again then it will not be hard
wushaw is offline
post #10 of 40 Old 07-22-2012, 06:06 PM Thread Starter
hepme70
Thanks for that clever laugh! Now I can sleep tonight.
Seriously though, does anyone know the correct tool [ the best] to remove these "flat" * heads? There is only room for some type of special tool. It must be fairly long and lay low, to get in that small overhead room.
Wow, what did I get myself into???
hepme70 is offline
post #11 of 40 Old 07-22-2012, 10:17 PM
Photog2000
It is a torx bolt. I think it is either a T50 or T55. You will need the socket type that you put on a ratchet. It helps to crawl underneath the jeep and locate the bottom of the bolts and spray some WD-40 on the threads and let it soak in for a bit too.
Why on earth are you taking the seats out of your jeep anyway?
Photog2000 is offline
post #12 of 40 Old 07-22-2012, 11:14 PM
Sundowner
I want to say that it's a T50...I was looking at mine today and thought it was either that, or a T45. Also, the only amendment I'd make is to use penetrating oil over WD-40...they both probably work, but I get better results when I hit stuff with penetrating oil five or six days ahead of time and then drive around for a spell.
Sundowner is offline
post #13 of 40 Old 07-22-2012, 11:21 PM
OhSethiO
the only one that can be a B-tch is the torx. especially in the older TJ's. when I bed lined my tub I had to grind off both the torx then re weld them on the bottom of the tub. WITH REGULAR bolts though! no more torx.
USN Hull #195
OhSethiO is offline
post #14 of 40 Old 07-22-2012, 11:26 PM
Photog2000
I personally use PB Blaster but I figured this guy would start asking questions as to what that is. Everyone knows what WD-40 is.
post #15 of 40 Old 07-23-2012, 12:09 AM
Necko2529
Necko2529's Avatar
We need to fill his profile out for him, maybe it will help us help him a little better...
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
JK front passenger seat removal Maine45 JK Wrangler Technical Forum 16 10-16-2015 12:34 PM
94 yj passenger front axle removal RustyzChopShop YJ Wrangler Technical Forum 16 10-03-2009 06:07 PM
YJ Right Front (passenger) Axle Removal silverwolf636 YJ Wrangler Technical Forum 2 01-30-2009 04:36 PM
Passenger seat removal innerchi TJ Wrangler Technical Forum 4 03-04-2007 06:36 AM
1998 Wrangler Passenger Seat Lift owensdw TJ Wrangler Technical Forum 3 11-20-2006 10:40 AM
