1998 TJ heater core replacement - non A/C - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 1998 TJ heater core replacement - non A/C
Spartan Locker's at all time LOW exclusive from ROCKRIDGE FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Bds fox ipf 2.0 racing series shocks now available at rock
Unread 11-02-2008, 02:02 PM   #1
dragginwagon406
We pulled this apart today and can say, not a lot of fun.
I'll keep it short for now, have some pointers for the next guy doing this job:
1. Remove your door switches so they don't get broke when removing the dash.
2. The last core box screw is behind the bracket holding the tube that connects the cowl drain.
3. Even though the nuts holding the core box to the fire wall make the studs turn, continue to turn them as they will still unthread out of the core box. You can remove them from the firewall later, wire wheel and put them back into the core box.
4. The after market heater cores do not match the factory - not even close. I was not comfortable trying to adjust the piping on the heater cores so to the factory I will go.
5. I prefer not removing the steering wheel, steering column or dash for that matter. I used ratchet straps to support the dash once it has been freed from the firewall.
I'll fill in more details later, just clearing a few things up right now.
dragginwagon406 is offline   Reply With Quote Quick reply to this message
Unread 11-02-2008, 02:46 PM   #2
06camarodude
Good advice! Do you plan to do a write-up for this? I checked out the instructions in my Hayne's Manual, and they definitely leave room for improvement. . .
Glad to hear everything is still coming along, even though it's not fun.
Check out my Gun Blog! Click Here!
Originally Posted by elsapo View Post
"Do not judge, or you too will be judged." Matthew 7:1
Originally Posted by AustinTJer View Post
That's a pretty decent crawl ratio, tell Matthew congrats. :2thumbsup:
06camarodude is offline   Reply With Quote Quick reply to this message
Unread 11-02-2008, 03:12 PM   #3
dragginwagon406
As I said, first the aftermarket heater core is not the same quality. The price ranged from 68.95 to $74.99. Autozone and Napa carried the exact same core, just different names on the box. Interestingly, NAPA had the lower price.
Quality aside, the aftermarket core pipes were not the same angle or length. If we were to try to bend these into position, it would likely result in a stress in the cooler which would lead to a leak. Did I mention this likely the worst job possbile on the Jeep.
Unread 11-02-2008, 03:52 PM   #4
dragginwagon406
Much of this has been covered in the FAQ and on Stu's website, but I'll add some pointers.
Disconnect and remove the battery.
Remove:
1. Center console
2. Glove box - unhook strap let hang down and remove
3. Full width trim panel at top of dash - pry this up by hand - here you can see the clips
4. Gauge cluster cover - top and bottom
5. Metal plate under the steering wheel.
6. HVAC control/radio/vent cover - remove the ash tray, 1 screw behind the ash tray, 2 screws on top of the dash and the bottom will pop out with clips similar to the top dash cover
7. 4 screws holding HVAC control to dash - the control will be tucked back through the dash when the dash is pulled from the firewall
Unread 11-02-2008, 05:43 PM   #5
Tom Hartz
1967 CJ5
Also if you have a dash cross bar on your cage like I do, plan on taking that out. The heater core is not hard, just allot of work and not fun.
Tom
Tom Hartz is offline   Reply With Quote Quick reply to this message
Unread 11-09-2008, 12:27 AM   #6
dragginwagon406
8. 4 nuts holding the dash to firewall on top and 2 behind passenger airbag
9. The 6 torx screws holding the dash to the door jam area
Slowly separate the dash from the firewall while looking for any wiring or hoses connecting them
10. Unplug the main wiring connectors (driver's side upper) and secondary connection (driver's side lower), passenger side connections, outer vent hoses - both sides
12. Unplug the vacuum control to the HVAC control panel(passenger's side mid)
13. Slide the HVAC control panel through the dash so the cable can remain attached to the core box
14. Unplug the HVAC control electrically - two plugs keep it attached to the main wiring harness
15. Remove the floor heater diffuser - this allows the core box to drop down - already removed in the photo below.
Unread 11-09-2008, 12:27 AM   #7
dragginwagon406
16. Remove the heater box screw near the fuse panel
17. Remove the 2 screws holding the fuse panel to thefirewall - this helps the box drop away from the firewall
18. Drain the radiator and disconnect the heater core hoses
19. Remove the nuts holding the heater box to the firewall (under the hood x5)
Also, disconnect the upper vaccum line in the tee which is attached to the upper stud in this photo.
Notice the bottom stud has 2 nuts, one holding the cowl drain and a second one behind holding the box. These by far are the most difficult part of the hole job(especially with a motor mount lift/body lift). Once the first nut is removed, use a wedge to hold the cowl drain toward the engine and remove the second nut/stud.
20. Remove the heater core box from the Jeep
Unread 11-09-2008, 12:36 AM   #8
bluejeep00
i pulled my whole dash and cage in no time but ive done it a couple of times its really not hard. also u dont have to un plug the wiring or at least i didnt ive just got 4 big holes to fill
00 TJ
3" lift kit coil spacers in the front
63mm throttal body and spacer
33 12.50 15 turxes mt's on 15 by 10 steel rims
cut fenders tuffy overhead cb no backseat
looking for any cheap parts
bluejeep00 is offline   Reply With Quote Quick reply to this message
Unread 11-09-2008, 12:58 AM   #9
Ryan2003TJ
It only takes about 10 minutes to remove the steering column and it is worth it to be able to get the whole dashboard out of the Jeep and out of your way.
Ryan2003TJ is offline   Reply With Quote Quick reply to this message
Unread 11-09-2008, 01:15 AM   #10
dragginwagon406
In my experience, 10 minute jobs turn into days...if it doesn't have to be molested, it's often best to leave it alone.
Moving the dash out gives plenty of room to get the core box out of the Jeep so you can replace the core.
Unread 11-09-2008, 10:38 AM   #11
Cowboy1629
Good information and pictures!
|______
|l ,[____],
l---L ľOlllllllO-
()_)-()_)--o-)_)
[I][B]...[URL="http://www.indyorv.com"]IndyORV[/URL]...[/B][/I]
Cowboy1629 is offline   Reply With Quote Quick reply to this message
Unread 11-09-2008, 10:45 AM   #12
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Ugh, that same job is staring me in the face with my son's Grand Cherokee and it's a harder more complex job than the TJ's is. Please, let me win the lottery so I can pay someone else to do that nasty job.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 11-09-2008, 01:00 PM   #13
dragginwagon406
Call me paranoid, but I think I've been smelling a little antifreeze from the wife's '03 Grand Cherokee too so I know what you mean.
Unread 11-21-2008, 11:19 PM   #14
97 SRH Jeep
So Does the napa one not fit? Good question for me since I just picked one up and plan on tear down tomarrow...
97 SRH Jeep is offline   Reply With Quote Quick reply to this message
Unread 11-23-2008, 08:57 AM   #15
dragginwagon406
Mine is non-A/C. The Napa/Autozone ones would not fit properly. The pipes were off enough that they would have required tweaking the pipes in multiple places to fit inside the core box. I could only imagine this leading to long term problems with leaking.
Another consideration is the efficiency in the core construction. The factory core has many more rows and fins for heat exchange. I checked the temperature drop of the coolant through the new factory core and it was between 40-45░F. Not sure the aftermarket core could duplicate that efficiency.
