1998 Mountaineer rearend swap - JeepForum.com
post #1 of 5 Old 05-10-2010, 04:34 PM Thread Starter
CHIEFROD
Has anyone ever swapped a 1998 mountaineer rearend onto a TJ? The rearend is off a 5.0 V8.
CHIEFROD is offline
post #2 of 5 Old 05-10-2010, 04:42 PM
BlueFlame
BlueFlame's Avatar
What axle is it?
Width?
gears?
brakes?
You do know it is not going to bolt in, right?
BlueFlame is offline
post #3 of 5 Old 05-10-2010, 04:44 PM
2GPS4ME
The mounaineer will have the Ford 8.8 rearend, a popular swap. Do a search for it, but the swap requires all the Ford mounts to be cut off, and TJ mounts to be welded in place.
WJ (WIFE JEEP) PROJECT COMING SOON
2GPS4ME is offline
post #4 of 5 Old 05-10-2010, 04:46 PM
BriansCJ
1994 XJ Cherokee
Isnt the Mountaineer a rapackaged explorer?
Should be the same as a regular 8.8 swap
BriansCJ is offline
post #5 of 5 Old 05-10-2010, 04:59 PM Thread Starter
CHIEFROD
Hey Guys (BlueFlame, 2GPS4ME, BrianCJ)
Thanks for the quick reply. I will have to go measure and do some further research on the Ford 8.8 swap. Again, thanks for the azmuith check!
Chief Rod
CHIEFROD is offline
yj to xj rearend swap?????????? jake89yj YJ Wrangler Technical Forum 11 02-21-2010 09:57 AM
mountaineer jmartin1 YJ Wrangler Technical Forum 7 04-12-2008 08:19 AM
Mountaineer Rack for LJ LVC2003 TJ Wrangler Technical Forum 13 02-10-2008 12:01 AM
Mountaineer Rack RUB1CON TJ Wrangler Technical Forum 5 08-05-2005 03:09 PM
Jeep Mountaineer... jeep123 YJ Wrangler Technical Forum 8 03-18-2005 01:37 PM
