1998 Jeep Wont Start, No Power To Coil Either - JeepForum.com
post #1 of 2 Old 04-08-2008, 12:38 PM Thread Starter
celicagt03jsn
I have done some work on my jeep recently. I blew a few fuses and replaced them and everything was working fine. I pulled the jeep in the garage and forgot i had something draining the battery. So, the battery died and I got the battery charged and put it back in. Now, the jeep will crank and crank all day long but will not start. If the key is in the on poistion, none of the gauges move what so ever. I do not know if thats normal or not, or if the jeep has to be started first for them to move. I do not know if I fried something in the ecm or if something else is wrong. I tested the wires going into the coil, and I get no voltage. I do not know what else to do. I hope someone can help. Thanks
celicagt03jsn is offline
post #2 of 2 Old 04-08-2008, 12:42 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The crank position sensor on the tranny bellhousing and the cam position sensor under the distributor cap are 2 sensors that commonly cause no-spark issues like you are having.
The cam position sensor can be tested. It should read 5 volts with the key on.
I'm sure the crank position sensor can be tested too, but I'm not sure how. One trick you can try is unplugging it and plug it back in. Sometimes you can get a few more starts out of a bad crank position sensor by doing this.
Wheelin98TJ is offline
Jeep wont start, intermittent power Mediarocker TJ Wrangler Technical Forum 7 02-19-2010 10:36 AM
got power wont start???? Ridgejeep YJ Wrangler Technical Forum 0 01-20-2010 06:47 AM
2.5 motor turns wont start no fire from coil vwjeep YJ Wrangler Technical Forum 12 01-13-2010 12:16 AM
1998 Wrangler will crank but wont start mrabear YJ Wrangler Technical Forum 6 05-09-2009 07:44 AM
1999 Jeep No Power Wont Start hooterlc TJ Wrangler Technical Forum 2 02-19-2004 02:50 PM
