1998 jeep tj wrangler gas gauge problems - Page 2 - JeepForum.com
post #16 of 20 Old 08-01-2012, 11:52 PM
Jonny Jeep
Jonny Jeep's Avatar
The actuator test is just a cluster test. If the gauge doesn't move correctly during the test - it should move the same as the other small gauges - there is a problem within the cluster. The test doesn't reset the gauges. It just shows if they are functioning correctly. If your gauge functioned properly during the test the problem would be elsewhere. As it doesn't function properly during the test the problem is with the cluster.
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is online now
post #17 of 20 Old 08-02-2012, 08:45 AM
keithert
keithert's Avatar
Today I filled the LJ up with gas. It was reading 1/4 tank. I put in 10.5 gallons and it went to full. With 8.5 gallons it should have been reading slightly under half a tank.
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #18 of 20 Old 03-30-2015, 10:11 PM
XJ_sinner93
Sorry to revive this but was the gauge ever fixed?
XJ_sinner93 is offline
post #19 of 20 Old 04-03-2015, 10:38 PM
shoe85251
It is a defect on older TJs right from factory. I stopped looking at my fuel gauge 3 years ago! I have a 1998 Sahara Tj and went through what you are going thru now. After many forums I found that out. Here is what works for me all the time, Set your mile counter to 0 everytime you fill up your tank and for me at 210 miles its time to get gas. I once just kept driving and ran out of gas at around 214/220 miles and had to have AAA bring me gas!! I know it sounds ridculous but believe me my days of wondering how much gas I have are OVER!! And it has never failed me.
shoe85251 is offline
post #20 of 20 Old 04-03-2015, 11:48 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
If I'm driving on the highway, going from my residence to Moab. The gas warning light comes on at about 300 miles and that means that I have about 2 gallons left in the tank and need to stop for gas in the next 30 miles, done it many times.
It works for me....
Knuckelhead is offline
gas , jeep , tj , wrangler
Will a 2002 jeep wrangler x, soft top fit my 1998 jeep wrangler? RTShea TJ Wrangler Technical Forum 2 09-27-2010 11:40 AM
1991 wrangler gauge problems countryboy15 YJ Wrangler Technical Forum 3 08-27-2009 07:07 PM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 05:42 PM
95 wrangler gauge problems mercenaryjdog YJ Wrangler Technical Forum 5 01-14-2009 09:23 PM
Gauge problems in 90 Wrangler the_nutt YJ Wrangler Technical Forum 8 02-22-2006 06:14 AM
