1998 jeep tj wrangler gas gauge problems - JeepForum.com
post #1 of 20 Old 07-29-2012, 04:10 PM Thread Starter
dustintgarner
ok so dont know if this has been askered yet, but i have a '1998 jeep wrangler sport 4.0 automatic'... and my gas gauge stays on empy all the time i have checked wires and fuses and took the cluster out and cleaned it and everything it still is not working !!!!!!! i have done the test on the cluster with holding the buttion and turning the key off and on ... and it doesnt move untill all the other gauges are all the way maxed out then it only moves half way, but in the test the other gauges will read half way and the gas will go back to e....... some one please help with this it is driving me crazy!!!! thanks
dustintgarner is offline
post #2 of 20 Old 07-29-2012, 04:39 PM
Holm-z
Holm-z's Avatar
Mine has not worked correctly in a few years... actually ever since I bought it! i reset my trip meter and go off of that.
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #3 of 20 Old 07-29-2012, 10:57 PM Thread Starter
dustintgarner
I could to that but I don't always fill it up. Plus the whole family drives it and you never know who or when it was filled up last .. And I am doing that now but it ran out one time at 188 miles then the time before that it made it 214 miles so don't really know bout that .... Wish I could just find out the problem and fix it !!!
post #4 of 20 Old 07-29-2012, 11:10 PM
LRod
Mine would go waaaay full when it wasn't grounded really good.
LRod is offline
post #5 of 20 Old 07-29-2012, 11:32 PM
Jonny Jeep
Jonny Jeep's Avatar
Remove the cluster and try tightening the screws at the back of the gauge. I had a screwed up gauge once and found a loose screw was causing the problem.
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
post #6 of 20 Old 08-01-2012, 12:43 AM Thread Starter
dustintgarner
I don't think the screws are loose but I will check again . Cause I have had it out and apart looking at it and I even tried the pencil eraser thing on the brass strips see if that would help and nothing even bent the prongs slightly to make sure it had a good connection like one of the blogs says on here .. But thanks I will check the screws!!!!!
post #7 of 20 Old 08-01-2012, 12:44 AM Thread Starter
dustintgarner
Any more ideas???? I would really like to fix this with out having to take to the dealer !!!!!
post #8 of 20 Old 08-01-2012, 05:27 AM
enforcer88
Bad sending unit? New to Jeeps myself so going out on a limb and saying it is in the tank along with the fuel pump. My gauge never goes over 3/4 tank.
enforcer88 is offline
post #9 of 20 Old 08-01-2012, 07:27 AM
keithert
keithert's Avatar
I just replaced the fuel pump on my 05 and now the gauge only reads less than half way up the scale. I think either the float level sender on the pump is defective or I somehow have it installed incorrectly. It's not a huge job to take down the tank if it is close to empty. Eventually I'll probably check the pump in the tank.
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #10 of 20 Old 08-01-2012, 02:43 PM
Jonny Jeep
Jonny Jeep's Avatar
It shouldn't be an issue with the sending unit as the gauge is controlled by the cluster and the Actuator Test as Jeep call it has been done and the gauge doesn't work as it should during the test. That suggests a problem with the cluster and a loose screw was the simplest thing I could think of. It's also possible that part of the gauge circuitry is screwed, but other that the actuator test I know of no way of testing the cluster.
post #11 of 20 Old 08-01-2012, 03:17 PM
keithert
keithert's Avatar
Can you tell me more about the actuator test? Is that done with a DRB scanner? I have access to a Sun solus scanner that performs some of the same functions.
keithert is offline
post #12 of 20 Old 08-01-2012, 03:56 PM
mukluk
Press and hold your odometer reset button then turn the ignition to the "On" position... the gauge cluster will then perform a lamp and gauge test.
mukluk is offline
post #13 of 20 Old 08-01-2012, 04:28 PM
keithert
keithert's Avatar
I did that just now but the gauge is still off.
keithert is offline
post #14 of 20 Old 08-01-2012, 06:46 PM
mukluk
Are you holding the reset button as you turn the ignition on?
mukluk is offline
post #15 of 20 Old 08-01-2012, 06:50 PM
keithert
keithert's Avatar
Yes, it went through the whole self test process and did move the gauge from quarter to half to full. The issue must be with the device in the pump itself.
keithert is offline
gas , jeep , tj , wrangler
Will a 2002 jeep wrangler x, soft top fit my 1998 jeep wrangler? RTShea TJ Wrangler Technical Forum 2 09-27-2010 10:40 AM
1991 wrangler gauge problems countryboy15 YJ Wrangler Technical Forum 3 08-27-2009 06:07 PM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 04:42 PM
95 wrangler gauge problems mercenaryjdog YJ Wrangler Technical Forum 5 01-14-2009 08:23 PM
Gauge problems in 90 Wrangler the_nutt YJ Wrangler Technical Forum 8 02-22-2006 05:14 AM
