1998 fuel filter - JeepForum.com
post #1 of 6 Old 03-08-2010, 02:46 PM Thread Starter
spdnjoe
1998 fuel filter
I feel like a total idiot asking this, but do the 98s have a fuel filter ? Is it external and servicable ?
I can't seem to find mine.
sorry guys
spdnjoe is offline
post #2 of 6 Old 03-08-2010, 02:48 PM
mdm
Farm Wheeler
It's at the base of the fuel pump which is inside the tank. It is considered a life of the vehicle filter and doesn't need replacing under normal conditions.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 6 Old 03-08-2010, 02:50 PM Thread Starter
spdnjoe
GREAT !
Thank you for the quick response !
That took a whole 2 minutes for an answer. I done the complete tune and just didn't want to overlook the fuel filter.
spdnjoe is offline
post #4 of 6 Old 03-08-2010, 03:13 PM
Jonny Jeep
Jonny Jeep's Avatar
The fuel pump is considered a lifetime unit but the thing at the base of the fuel pump is just a strainer. There is a second one in there too.
The actual fuel filter is a combined fuel filter/pressure regulator. It sits on top of the fuel pump module and is accessible once the tank is dropped, without removing the fuel pump.
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is online now
post #5 of 6 Old 03-08-2010, 03:24 PM
Stu Olson
Stu Olson's Avatar
If you believe you have a fuel delivery issue, suggest following the test procedures in the FSM....it accounts for both pressure, volume, and leak down rate, IIRC.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #6 of 6 Old 03-08-2010, 03:44 PM Thread Starter
spdnjoe
I'm not having any issues. I just like to keep up on maintenance instead of waiting for something to go wrong before paying attention to it.
spdnjoe is offline
Surging and poor performance.....fuel filter? fuel pump? lwoods TJ Wrangler Technical Forum 17 09-09-2009 07:10 PM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 04:42 PM
Fuel filter replacement - How do I depressurize fuel system? Rproject YJ Wrangler Technical Forum 13 11-23-2008 08:34 AM
fuel pump?fuel filter?relay? garoughrider YJ Wrangler Technical Forum 2 02-26-2008 05:23 AM
1998 TJ Fuel Injector a-jeep-r TJ Wrangler Technical Forum 1 05-31-2007 10:18 AM
