1998 -> 2001 D30&D35 4.10 swap - JeepForum.com
post #1 of 4 Old 09-07-2012, 08:53 AM Thread Starter
NotaRubi
Morning guys. Ive had tonnes of questions answered from viewing this website and figured that I officially became a part of it.
I have a question regarding a axle/gear swap I'm looking at. I have the opportunity to purchase both front and rear ends from a 1998 TJ with 4.10's I currently have the unfavorable D30\D35 3.07 garbage in my 2001. Whether or not the rear has leaf springs, can I just take the guts out of either and throw all of it in my current set-up? I just replaced my front wheel bearings and u-joints as well as ball joints so I'd like to keep that stuff in use.
I'm expecting to rebuild the axles, ie. new bearings, seals, ect, and would like to know of any other hidden expectations I might be looking at.
Thanks, and I hope to hear from someone!
Cheers.
NotaRubi is offline
post #2 of 4 Old 09-07-2012, 09:14 AM
mdm
Farm Wheeler
The '98 has the same suspension your '01 has. If the '98 axles are in good shape why not just put them under your rig? Why do you feel you need to swap the gears into your current axles? You can move your new unit bearings, shafts, rotors,... to the '98 axle. This would be a lot simpler than swapping the gear sets into your current axles.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 4 Old 09-07-2012, 09:36 AM Thread Starter
NotaRubi
Thanks! That's the answer I was looking for!
When reconnecting the yolks to the drive shafts, would there be the need to setup the back-lash? (I think that's the right term).
Thanks for the quick reply.
NotaRubi is offline
post #4 of 4 Old 09-07-2012, 09:43 AM
mdm
Farm Wheeler
No. The back lash is internal between the ring and pinion gears. If you just swap the axles, you won't be messing with the gears in any way.
I would just remove the covers, clean the housings out with brake cleaner, do a good inspection of the gears (don't remove or loosen anything, just look), replace the covers, and refill with new fluid.
Once you have the 4.10 axles installed you will need to bleed the brakes.
mdm is offline
axle , gears , swap
Engine Swap in 2.5 1998 Wrangler JeepMartin TJ Wrangler Technical Forum 2 02-07-2012 11:35 AM
1998 Wrangler TJ 4.0 motor in a 2001 Wrangler TJ zachzuke24 TJ Wrangler Technical Forum 30 01-06-2012 02:44 PM
Post 2001 to pre 2001 manifold swap ? wayfastwhitey44 TJ Wrangler Technical Forum 6 12-05-2010 01:55 PM
1998 Mountaineer rearend swap CHIEFROD TJ Wrangler Technical Forum 4 05-10-2010 03:59 PM
2001 Hard top onto 1998 CWD98TJ TJ Wrangler Technical Forum 3 11-02-2008 07:03 PM
