1997 TJ Wrangler 4.0. Misfire codes - JeepForum.com
post #1 of 5 Old 08-14-2011, 06:29 PM Thread Starter
rmitchell86
Check engine light on, codes for multiple miss fires. I replaced the Spark plugs with OEM copper tops, replaced the spark plug wires with Bosch wires, replaced the Cap and Rotor, Had injectors cleaned and checked, I guess i can order the Jeep OEM plug wires but do not know what else to do!
It seems to idle and run great!
rmitchell86 is offline
post #2 of 5 Old 08-15-2011, 02:00 PM
Jonny Jeep
Jonny Jeep's Avatar
Welcome to the forum. Bad batteries or connections can cause all sorts of problems on Jeeps. Charge the battery up using a proper charger and get it load tested to make sure it isn't the battery causing the problems. Also remove and clean up the battery connectors and terminals so they are bright before refitting. Hopefully it's something simple like that.
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
post #3 of 5 Old 08-15-2011, 02:10 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Did you clear the codes after doing all the work?
Wheelin98TJ is offline
post #4 of 5 Old 08-15-2011, 05:31 PM
WarPig7
Like he said, clear the codes. Drive it for a while and recheck if you need.
WarPig7 is offline
post #5 of 5 Old 08-15-2011, 06:23 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
'97 and early '98 had some bad batches of valve springs installed which will eventually cause multiple '43' codes which are the misfire codes. No amount of ignition component changing will help with this particular issue. The fix is to replace the valve springs and, possibly, a valve job if the misfires were ongoing long enough.
The factory issued a TSB (Technical Service Bulletin) for this issue and it basically just says replace the springs and clean the combustion chambers afterwards with Mopar CCC (combustion chamber cleaner). A TSB is not the same as a Recall so you'll get no $$$ assistance from the factory or dealer fixing this problem.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
misfire codes p0300 cooltoolguy TJ Wrangler Technical Forum 10 12-15-2014 12:17 PM
Cylinder Misfire Codes RowJ TJ Wrangler Technical Forum 0 02-19-2011 08:27 AM
Cylinder Misfire Codes RowJ TJ Wrangler Technical Forum 3 11-09-2010 07:15 AM
Misfire codes, now PO320.. Panhead TJ Wrangler Technical Forum 36 01-04-2010 04:05 PM
Any fix for cam thowing misfire codes? AlexTJ TJ Wrangler Technical Forum 0 01-15-2008 02:12 PM
