1997 TJ camshaft sensor: myth or fact? - JeepForum.com
post #1 of 8 Old 03-05-2010, 02:57 PM Thread Starter
wrangler97
Overbuild
wrangler97's Avatar
I think I need to replace the camshaft position sensor in my '97 TJ. I have been searching for the part and can't find it to save my life! My Haynes manual says that it was in the 2000, but fails to mention the '97. Did the '97 come with a camshaft sensor? I recently replaced the crankshaft sensor and that didn't solve all the issues. Any input from the think tank that is Jeep Forum would be greatly appreciated!
1997 Wrangler 6cyl 5-spd; 4" short arm, 35X12.50's, all the supporting goodies...
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats"
wrangler97 is offline
post #2 of 8 Old 03-05-2010, 03:00 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
It's inside the distributor.
GOLENJEEPTJ is offline
post #3 of 8 Old 03-05-2010, 03:02 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yep, pull the distributor cap off & you'll find the sensor underneath that thin round plastic protective cover below the rotor.
Jerry Bransford is offline
post #4 of 8 Old 03-05-2010, 07:26 PM Thread Starter
wrangler97
Overbuild
wrangler97's Avatar
Alright; thats what I thought. How much of a hassle is that sucker to replace?
post #5 of 8 Old 03-05-2010, 07:39 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Typically?
1) Remove distributor
2) Disassemble distributor (requires removal of a roll pin through the drive gear, then the shaft pulls out from the top. Suggest you make witness marks on the gear and shaft - it should not matter whether you get the gear 180* around, but why take chances?)
3) Remove/replace sensor
4) Reassemble distributor (Clean shaft. Make sure shaft bore is clean. Drop shaft through housing. Replace gear. Align witness marks made in (2). Replace roll pin.)
5) Replace distributor, making sure proper timing is retained.
Easier said than done - but the last time I had to change a CMP (on RENIX,) it took me about two hours. Then again, I've done plenty of distributors before, and I've been doing this sort of thing for a while...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #6 of 8 Old 03-05-2010, 08:05 PM
GOLENJEEPTJ
What is a CMP your talking of?
post #7 of 8 Old 03-05-2010, 08:06 PM
GOLENJEEPTJ
Changing a CPS is a piece of cake on a 4.0 distributor TJ.Maybe 15 minutes?
post #8 of 8 Old 03-05-2010, 09:57 PM
BarneyJEEP
2 screws on cap, pull rotor button, unplug CPS, lift off dizzy....reverse process for install...should take all of 2min to replace it
BarneyJEEP is offline
camshaft , camshaft position sensor , p0340
Camshaft Position Sensor? Benny2Times TJ Wrangler Technical Forum 3 10-02-2008 03:27 PM
camshaft position sensor? LeftoverSalmon TJ Wrangler Technical Forum 7 07-08-2008 11:01 AM
Does 97 TJ have Camshaft Position Sensor? spdrmn44 TJ Wrangler Technical Forum 2 08-30-2007 04:40 PM
Detroit soft locker (myth or fact)? raider_man007 TJ Wrangler Technical Forum 10 03-10-2007 01:22 PM
Camshaft Positioning Sensor mance YJ Wrangler Technical Forum 2 06-14-2005 03:50 PM
