Quantcast 1997 tj 5sp tansfer case tubing mistake - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 1997 tj 5sp tansfer case tubing mistake
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 01-29-2006, 08:30 PM   #1
phllips79
I am such a dope. Hope some of the senior members get a laugh out this one....
When I reinstalled my radiator after a failed water pump, I was not paying attention when I was hooking up the resevoir tubing. I mistakingly hooked the coolant resevoir tube to the transfer case breather tube(?) well I only knew somthing was wrong when smelled cooland but only noticed traces of it and then realized that the tubing was incorrect.
I now get a little sputter of transer case lube/oil out of the tube? How worried should i be and how quick should I change my coolant and manual transmisson fluid? Contamination? Mixing?
phllips79 is offline   Reply With Quote
Old 01-29-2006, 08:43 PM   #2
greenmachine99
greenmachine99's Avatar
I would definitly change the t-case fluid and flush the radiator to be safe.
greenmachine99 is online now   Reply With Quote
Old 01-29-2006, 09:05 PM   #3
18to80DDC
Built Not Bought
18to80DDC's Avatar
if it is the tube right next to the radiator, it is the front axle breather, the transfercase tube only comes up to the top of the transmission bell, you would have to work really hard to get it connected to the radiator.
2001 4.0L Wrangler Sport - 3.5" lift on 33's
1973 CJ5 360 - 4" lift on 35's
1982 CJ7 360 - 2" lift on 32's
1971 Series III E-type Jaguar V12 - no lift...
18to80DDC is offline   Reply With Quote
Glock Forum
