1997 TJ with a 4" suspension lift. 33" or 35" tires? - JeepForum.com
post #1 of 12 Old 03-02-2010, 06:33 PM Thread Starter
natedogg78n
What size tires is everyone running with a 4" suspension lift? Any suggestions on tires with good street wear?
natedogg78n is offline
post #2 of 12 Old 03-02-2010, 06:43 PM
MikeUnlimited04
33's will fit great. 35's will fit great with a little fender trimming, 1in of Body Lift, or both.
BFG KM2's are sexy.
United States Air Force F-15E Strike Eagle Crew Chief
Silver JEEP Club Member #36
MikeUnlimited04 is offline
post #3 of 12 Old 03-02-2010, 06:47 PM
randymack
i have 33's on my 3.5 lift....without needing better brakes or trimming so i went with that.
randymack is offline
post #4 of 12 Old 03-02-2010, 06:50 PM
banone403
if it was like it was before i think the 35" km2s are less than the 33s. run a 1" bl and some 35s. If you have a 5 spd i wouldn't worry about brakes until you get the money. I stopped my 35s fine in my tj and downshifting helps a lot.
banone403 is offline
post #5 of 12 Old 03-02-2010, 06:52 PM
MikeUnlimited04
Don't forget, gears are just as important as lift and tire size. running stock gears with 35's is gonna be hell. I know, I drove with 3.07's and 35's for 6 months. no fun. 4.88's with a 5spd are ideal.
post #6 of 12 Old 03-02-2010, 06:56 PM
TexanTJ
2014 JK Wrangler
Back in the day, I ran 4" of lift with 33" Kumho MTs (wore great)
then I ran 35" Pro Crap Mts. (they were noisy and wore out real fast)
The 35's fit fine on mine... just make sure your bumpstops are set correctly with whatever setup you choose to go with
2014 JKU Sport - Wife's Mall Crawler on 35s. Badlands Winch, 2" Coil Spacers, 1" PA BL
1999 F250 7.3 - 290K Miles and Counting
"I am not going to censor myself to comfort your ignorance."
TexanTJ is offline
post #7 of 12 Old 03-04-2010, 07:33 PM
PurpleWave
with 4 inches of lift and 33's is there any other work to the driveshafts or anything that you have to do?
PurpleWave is offline
post #8 of 12 Old 03-04-2010, 07:39 PM
jonwood
36" Iroks here with some trimming .4"springs, NO body lift
03 Rubicon on 36's and LONGFIELD CV's
jonwood is offline
post #9 of 12 Old 03-04-2010, 08:46 PM
Max-Q
1983 CJ7
I run 35" KM2 with a 4" lift.
You do understand there is more to running 35's than just the lift size? You will also need proper gearing, upgraded brakes, upgraded steering and stronger axles.
1997 Jeep TJ
1983 Jeep CJ7
2011 JK Unlimited Rubicon
Max-Q is offline
post #10 of 12 Old 03-04-2010, 09:36 PM
Photog2000
Just mounted my 35" KM2's this morning, and running 3" lift with NO body lift. I'm sure they are going to rub a bit when we go to Badlands in a couple weeks. I will just start cutting when they do.
Photog2000 is offline
post #11 of 12 Old 03-04-2010, 09:42 PM
thejafe
thejafe's Avatar
It's a lot cheaper to properly run 33's than it is to properly run 35's. If funds are in any way an issue stay away from the 35's.
thejafe is offline
post #12 of 12 Old 03-04-2010, 10:41 PM
glockster
My recommendation for a tire is the Mickey Thompson MTZ's. Could not be happier. Have siping, the KM2's don't, at least the one I had didn't. The Mtz's are quieter in my application also. I went with 285/75/16's (33's) on RE 3.5" springs.
Marco
glockster is offline
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
max __" tires on a 3" body 4" suspension! ACB2010 TJ Wrangler Technical Forum 30 05-18-2009 07:24 PM
RC 1997-06 Jeep TJ 4" Suspension Lift elephantrider TJ Wrangler Technical Forum 4 05-11-2009 10:08 AM
1" or 2" Spring Spacer with 4" Suspension Lift on 2000 TJ iBkickinit TJ Wrangler Technical Forum 12 03-20-2006 08:25 AM
