1997 tj - JeepForum.com
post #1 of 3 Old 07-27-2010, 07:03 PM Thread Starter
BubbaNTx
1997 tj
I Have put this on here before about a Severe Vibration. I replaced both Front Hubs. Both axle wheel Joints. Checked the Front axle Gears O.K. Tonight Pulled the Rear drive Shaft, To do the U-joints. Dropped the Rear Diff. Cover and Found some tore up Teeth on the Ring Gear. Looked at the Pinion Gear cant find anything Wrong there. Looked at the Cluster gears Look Fine also. I Dont Know what gears in It because the Tag was Covered in Gunk. Anybody Had Just a Ring gear get trashed without Taking out the Pinion or the Spider Gears...
BubbaNTx is offline
post #2 of 3 Old 07-27-2010, 07:22 PM
NMLJ
NMLJ's Avatar
If your jeep has been regeared there is the chance they were set up incorrectly...
/l ,[___],
l--L --OlllllO-
()_) ()_)-o-)_)
-2006 Impact Orange LJ-
MY BUILD THREAD
THE HARDEST THING ABOUT A ZOMBIE OUTBREAK WOULD BE PRENTENDING NOT TO BE EXCITED
NMLJ is offline
post #3 of 3 Old 07-28-2010, 07:15 AM Thread Starter
BubbaNTx
No the Jeep has never been Re-geared Has 106k on them. Just Noticed a Vibration getting worse and worse. then it started a clunking Noise been chasing it for a while now.
BubbaNTx is offline
ring , gear , axle , metal , tore up
First Vin. # for 1997 TJ pismo61 Wrangler General Discussion 9 02-03-2014 05:23 PM
1997 TJs 442Wrangler TJ Wrangler Technical Forum 23 06-10-2009 10:20 AM
Looking at 1997 Jeep25 TJ Wrangler Technical Forum 5 08-04-2007 11:39 AM
Changes from 1997 til now MCanavan TJ Wrangler Technical Forum 6 02-06-2005 10:02 AM
