1997 Jeep Wrangler--stumbling!! - JeepForum.com
post #1 of 4 Old 05-23-2009, 01:01 PM Thread Starter
Wranglergirl_co
I'm at the end of my rope.. I did a tune up on my jeep.. Plugs, rotor, cap, wires.. When I buttoned it up, it started to stumble and jerk.. This after warming up and not when I steppped on the gas.. it was on level ground, or when I decelerated.. when I put my foot into it, didn't hesitate once.. but lots of hesitation, "stumbling", coughing when I took my foot off the gas.. Weird!! so I decide to change out the coil, Camshaft position sensor (in the distributor for my Wranger) and the Crank shaft position sensor.. Now it runs bad all the time.. stumbles, coughs, hesitates.. Got code 11 three times on my dash when I checked my codes and now the check engine light is on.. Anyone with Jeep knowledge.. PLEASE HELP!!!
Wranglergirl_co is offline
post #2 of 4 Old 05-23-2009, 01:05 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Code #11 refers to no crank reference signal detected at PCM.Check all your connections first.You could easily back out the crank sensor and re-install it again.
GOLENJEEPTJ is offline
post #3 of 4 Old 05-23-2009, 01:08 PM
GOLENJEEPTJ
Did you double check you plug wires also, to make sure there at the proper plugs and #1 cyl is line up with cap and rotor in dist?
post #4 of 4 Old 05-24-2009, 03:29 AM
Skyryder
Well for what it's worth, , ,
I changed my plugs about a month ago @ 65K, result was better gas mileage and smoother running. Just last week got around to the cap & rotor, , about three times a day the Jeep would "cut out" and sputter but kept running and all would be fine again. Checked the part with no visible problems, , replace with the "old" cap & rotor now it runs fine again. Auto zone will be getting these back.
PS. No codes
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 09:26 AM
1997 Jeep Wrangler 2.5 wont run JDiMassi TJ Wrangler Technical Forum 13 02-10-2009 06:32 PM
1997 Jeep Wrangler 2.5L 4 cyl... JeepMan905 TJ Wrangler Technical Forum 11 05-31-2007 02:24 PM
Problems with my 1997 Jeep Wrangler SE. PLEASE HELP! acleme1 TJ Wrangler Technical Forum 17 04-03-2007 10:02 PM
Jeep Wrangler 1997 problem jappe TJ Wrangler Technical Forum 30 01-02-2006 09:42 PM
