1997 Jeep Wrangler Noises - JeepForum.com
post #1 of 9 Old 09-18-2005, 12:41 PM Thread Starter
Beach Boy
My wife and I just bought a 1997 Jeep Wrangler. There is a chirping noise that is intermittent. Sometimes, it is very loud upon ignition, sometimes just when driving with no noticeable pattern. Occasionally, it will be absent for quite a while, sometimes for a whole day. We had the belt replaced - first with a Delco belt and then with a factory belt. (The mechanic hoped there would be a slight difference in size.) It sounds like metal to metal to me, but my wife doesn't hear it that way. There is also an occasional "clunking" sound underneath the carriage. We had the whole rear end replaced right after we bought it. It had Detroit Lockers that had incorrectly installed and had chewed up the gears. Also, the rear brakes had been installed backwards on the right side. This has been corrected. It is much more stable now and the gas mileage has improved with the replacement of a very dirty air filter. The power steering fluid was empty but has been replaced.
Can someone please shed a light on these noises?
Beach Boy is offline
post #2 of 9 Old 09-18-2005, 03:10 PM
tpoag
2010 JK Wrangler
My 97 had the same "chirping" noise. Found out it was the safety catch on the hood. The hood latches let the hood bounce just slightly and the safety catch rubs metal to metal. I smeared a little grease on it and the noise stopped.
Worth a try!!!
Terry
tpoag is offline
post #3 of 9 Old 09-18-2005, 03:56 PM
joeyt17
in regards to the "clunking" one of the best sources of this clunking is a result from part of the trasnfer case shifter tapping on the the tub of the jeep. its a very common problem and there are a few ways to take care of it...
heres one good site with a description on the problem, and he has tons of information/write-ups that you may find useful!
http://www.4x4xplor.com/T-CaseTSB.html
best of luck diagnosing and solving the chirping problem, hopefully this is the cause and solution ot the clunking you are experiencing
joeyt17 is offline
post #4 of 9 Old 09-18-2005, 06:28 PM
cali_gurl_
That sounds exactly like my car did!! Turns out it was the catalyzer that was broken. There's an 8-year/80,000 mile warranty on it. I have a 1997 wrangler, and of course my warranty had expired a months earlier! If that's the same case for u, it's like $500 to get it fixed....
cali_gurl_ is offline
post #5 of 9 Old 09-18-2005, 09:46 PM
erickpl
erickpl's Avatar
Do that TSB yourself. 20 minute job at most. Also the hood does make a squeak and I did have my catalytic replaced. No squeaks or clunks here now!
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #6 of 9 Old 09-19-2005, 08:12 AM
river rat
Forum porn star...I guess
river rat's Avatar
Mine has so many knocks and squeeks it sounds like a drumset
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline
post #7 of 9 Old 09-19-2005, 08:14 AM
river rat
river rat's Avatar
Just wanted to see 1000
post #8 of 9 Old 09-19-2005, 09:44 AM
erickpl
erickpl's Avatar
Can you perhaps explain a bit more about whereabouts the noise is coming from?
Engine bay (belts)
Front of vehicle (hood latches not securing properly)
underneath vehicle (transfer case needing TSB or catalytic converter)
Passenger or driver side? (passenger = catalytic?, driver = t-case)
It would help us isolate what it might be. Have you tried beating on the catalytic while it is cool? If it rattles, that is probably your source of noise. Have you tried lifting up on the hood while it is latched? If it squeaks, that may be the source...
IE Tell us more.
-Paul
erickpl is offline
post #9 of 9 Old 09-19-2005, 10:03 AM
Scuba Jeepster
Off-Road Solutions
Scuba Jeepster's Avatar
It can be several things. Crawl under the jeep, have your wife rock it back and forth, jumping on the bumper some. Once you isolate it to a general area we can help you diagnose it.
Synthetic Winch Line Recovery Gear 4x4 Parts
Scuba Jeepster is offline
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 10:26 AM
PCV Valve for a 1997 Jeep Wrangler NORCALROOTS TJ Wrangler Technical Forum 0 06-24-2009 11:00 AM
1997 Jeep Wrangler 2.5 wont run JDiMassi TJ Wrangler Technical Forum 13 02-10-2009 07:32 PM
1997 Jeep Wrangler 2.5L 4 cyl... JeepMan905 TJ Wrangler Technical Forum 11 05-31-2007 03:24 PM
Problems with my 1997 Jeep Wrangler SE. PLEASE HELP! acleme1 TJ Wrangler Technical Forum 17 04-03-2007 11:02 PM
