1997 Jeep Wrangler 2.5L 4 cyl... - JeepForum.com
post #1 of 12 Old 05-30-2007, 04:49 PM Thread Starter
JeepMan905
Hi everyone,
I recently just bought my first wrangler and love it! However, I noticed today that it did not come with an owners manual. I noticed this because I was checking my fuses under the hood and noticed that some of them are blown or not working. I called a few Jeep dealers to see if they could fax me a page of what the fuses are for and what they do, but they couldn't. So I was just wondering if any1 has a printout or anything that will tell me what the fuses are for. I have numbers, and colors, but the fuse box does not say what the fuse does. It says "read owners manual". I need to know what does what and have no way of finding it out. Thanks alot guys, hope ya can help!
JeepMan905 is offline
post #2 of 12 Old 05-30-2007, 05:36 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
check http://www.stu-offroad.com/index.shtml it may be on there,
also where in PA
RnEmOvr is offline
post #3 of 12 Old 05-30-2007, 05:38 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Get a flashlight and you will find that the fuse box is labeled at each fuse position. The labels are cryptic but usable.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #4 of 12 Old 05-30-2007, 09:29 PM Thread Starter
JeepMan905
i am from Lancaster, and also it does not say it on the fuse box, i looked 2 times. The relays and some of the smaller fuses are labeled but the bigger fuses on top are not. It says refer to owners manual.
post #5 of 12 Old 05-30-2007, 09:33 PM Thread Starter
JeepMan905
thanks for that site. however, it didnt have what i need...any1 else have any suggestions?
post #6 of 12 Old 05-30-2007, 09:38 PM Thread Starter
JeepMan905
i dunno maybe if i give some1 the fuse #'s and if they have the same year jeep, they can look in their manual and tell me what they do?
post #7 of 12 Old 05-30-2007, 09:57 PM
SJP
TJ Wrangler
From page 181 in the 1997 Jeep Wrangler Owner's Manual, 2nd Ed, 1996 Chrysler Corp.
2 40A Orange Starter Relay/ Ignition Switch - Run Only
3 30A Green Battery Feed to Ignition Switch - Run, Start, Acc.
4 40A Orange Exterior Lighting
5 20A Yellow Acc., Power Outlet
6 30A Green Auto Shutdown Relay
7 20A Yellow Auxiliary Coolant Fan Relay (2.5L Only)
8 Open
9 20A Yellow Multifunction Switch
10 30A Green Headlights
11 40A Orange High Blower Relay
12 Open
13 30A Green ABS System Relay
14 40A Orange ABS Pump Relay
15 30A Green Heated Back Light Relay
16 20A mini Yellow Fuel Pump Relay
17 10A mini Red Interior Courtesey Lights, Ignition Off Draw (I.O.D.)
18 Open
19 10A mini Red A/C Clutch Relay
20 20A mini Yellow
21 Open
Steve
Minister of Propaganda
SJP is offline
post #8 of 12 Old 05-31-2007, 06:28 AM Thread Starter
JeepMan905
^thanks that helped alot. however, the fuse that was blown was #5, and the other 2 (#7, & #15) were not even in. therefore i am not sure if i should put #7 back in, or just all 3 of them. do you know exactly what power outlet, aux coolant fan relay, or heated back light relay do? meaning what all does the power outlet control? i have a electric fan so i dont think ill need #7, and i have no idea what a heated back light would do?
post #9 of 12 Old 05-31-2007, 08:04 AM
rudyyj
in my factory service manual 7,8,12,18,21 should be empty
fuse 15 is for the rear window defogger on hard tops and is empty on soft tops
fuse 5 is the cigarette lighter / accessory position fuse
replace number 5 the rest you don't need...#5 can blow because of someone being stupid with something they plugged into the cigar lighter. seeing you just bought it, i would just replace it and see if it blows again before i looked any further
rudyyj is offline
post #10 of 12 Old 05-31-2007, 10:47 AM
SJP
TJ Wrangler
The #5 fuse is for the cigarette lighter. #7 Sounds to be for an electric A/C cooling fan. #15 sounds to be the rear defroster, but I'm not certain. My 1998 FSM lists it as such, but they vary from year to year, so it might be different.
What you have listed above is verbatim from the 1997 Owner's Manual. As I don't have a specific 1997 FSM, I can't check the wiring diagrams to verify either #7 or #15.
Steve
SJP is offline
post #11 of 12 Old 05-31-2007, 10:48 AM
SJP
TJ Wrangler
Is yours specifically a 1997 FSM? If so, this wouldn't be the first time that the Owner's Manual and the FSM weren't in strict agreement with one another.
Steve
SJP is offline
post #12 of 12 Old 05-31-2007, 02:24 PM Thread Starter
JeepMan905
thanks for all the help guys, really appreciate it
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 09:26 AM
1997 Jeep Wrangler--stumbling!! Wranglergirl_co TJ Wrangler Technical Forum 3 05-24-2009 03:29 AM
1997 Jeep Wrangler 2.5 wont run JDiMassi TJ Wrangler Technical Forum 13 02-10-2009 06:32 PM
Problems with my 1997 Jeep Wrangler SE. PLEASE HELP! acleme1 TJ Wrangler Technical Forum 17 04-03-2007 10:02 PM
Jeep Wrangler 1997 problem jappe TJ Wrangler Technical Forum 30 01-02-2006 09:42 PM
