1997 Jeep Wrangler 2.5 wont run - JeepForum.com
post #1 of 14 Old 10-30-2008, 04:33 AM Thread Starter
JDiMassi
1995 XJ Cherokee
hey guys im gonna write a little story for yas here im at a loss we have this vehicle at our shop and its been here tooo long im missing something and i hope yous can help
got the vehicle in after the guy blew his 2.5 didnt want us to get the engine so he got a 95 2.5 and swapped everything over from his 97 put it in and it wont run im getting a code 11 or p1391 replaced the crank sensor check all wiring replaced the cam sensor or i think they call it the stator/pickup on distributor and cleared codes and it cranks and cranks and cranks and fires but will run horrible and i have to feather the gas to keep it running its not drivable
also replaced injectors with a grand cherokee set as the orig ones wouldnt spray
is there a special procedure for setting the timing on a 97?
firing order is right
timing may be off i set distrib as it says in chilton manual but i never worked on a 97 so any input would be greatly appreciated guys id like to get rid of this vehicle
fuel pressure is at 46 while cranking to
also when engine is if you want to call it "running" the tach is alll over the place when i know engine is barely at 1000rpm it will bounce to 6k then to 4k then down to 2k its weird
thanks again guys
JDiMassi is offline
post #2 of 14 Old 11-08-2008, 02:58 PM Thread Starter
JDiMassi
1995 XJ Cherokee
97 2.5 4cyl m/t
replaced distributor as bearings felt a little sloppy .......still no change
drained gas tank put fresh fuel in ....no change
can anyone send me a picture of there timing top dead center a pic of the distributor so i can see where maybe i got the rotor off a little bit
JDiMassi is offline
post #3 of 14 Old 11-08-2008, 03:05 PM
Luckyduck
I wish I could, but it is pitch black here.
Did you make sure you are getting spark at all the plugs? replace the plugs? did the guy say the 95 engine worked fine? did you get the wiring harness with the 95 engine?
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build
Luckyduck is offline
post #4 of 14 Old 11-08-2008, 03:51 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
thanks again guys
Did you put a new paper gasket on your crankshaft sensor? If you didn't that is probably your problem!
GOLENJEEPTJ is offline
post #5 of 14 Old 11-11-2008, 04:55 PM Thread Starter
JDiMassi
1995 XJ Cherokee
no paper gasket on sensor old origional didnt have one ??
are they flywheel and clutch asseblys different from 95 to 97 the guy left the clutch flywheel and all on fomr the 95 motor and put in the 97 i talked to a jeep service guy and he said maybe flywheel as im getting the code 11 on the dash or (p1391) so im almost out of options here prolly gonna pull engine out and replace clutch flywheel and check front timing no ones opened up timing cover but who knows
new plugs wire cap rotor distributor cam sensor crank sensor battery its about time to give up lol
JDiMassi is offline
post #6 of 14 Old 11-12-2008, 03:23 AM Thread Starter
JDiMassi
1995 XJ Cherokee
i checked on the flywheels no way there different but what i did notice
2 different part numbers for crankshaft position sensors
1 for the 1995 jeep (which i think i have on it now)
1 for the 1997 jeep (that i should have on there but do not)
i think i may have screwed up when i ordered it so im gonna have the parts store bring me another one for the 1997
i just want to keep you guys up to date
JDiMassi is offline
post #7 of 14 Old 11-20-2008, 10:56 PM Thread Starter
JDiMassi
1995 XJ Cherokee
NOOOOO LUUUCCCKKK errrrrrr
any suggestions here guys im at a loss and thinking of pulling the engine out
im not ready to say the flywheels bad but i wont know till i pull it all out right?
changed the sensor and still get code 11 or 1391 and the thing wont run unless i feather the throttle and its not even lot driveable and the tach is alllll over the place which i still cant figure out
the rotor on the distributor at 0 degrees tdc is just touching the number one terminal which is what the dealer told me to set it at
any ideas similar problems any input appreciated
46psi fuel pressure
JDiMassi is offline
post #8 of 14 Old 11-21-2008, 04:22 PM
Luckyduck
I have no idea but I will give you a bump. I would not think you need to pull the engine. But i guess you have the option of pulling the engine or transmission...
CentralMass4wd.com
my build
post #9 of 14 Old 11-21-2008, 06:45 PM
little4x4
i put an older motor 2.5L in my 97 tj when i had it and found out the tooth count is diff on the crank shaft i could get it started the tach would go all over the place it would only run with the throttle almost wide open... and it ran like crap... had to pull the motor and swaped out the flywheel (5 speed) and all was good ran just fine after that. I don't know what year the engine came out of but it was not MPI it was throttle body inj. i hope this helps.
00 tj Old man emu susp. 1" bl 285x75 Procomp Xterrain's warn x8000i in an ARB fnt bumper custom rear with tire carrier, high lift jack locked in fnt and LSD in the rear, sway bar disconnect, steering engine and fuel tank skids, 4L engine, 5 speed tranny, 4.10s and a few other things.
little4x4 is offline
post #10 of 14 Old 11-26-2008, 07:21 PM Thread Starter
JDiMassi
1995 XJ Cherokee
little 4x4 you just answered everything i was asking the motor is out of a 95 tbi engine and the guy put the 97 fuel inj stuff on and i think what you said makes perfect sense so im gonna change the flywheel
whats easier pulling engine or pulling tranny lol
weird thing is parts store lists same part number for 95 flywheel and 97 flywheel weird??
unless the motor is in fact not a 95 and maybe a 92 or older with tbi i know for a fact it was tbi cuz the guy pulled all that stuff off im gonna change the flywheel thanks again buddy ill let yous all know
JDiMassi is offline
post #11 of 14 Old 01-26-2009, 06:24 PM Thread Starter
JDiMassi
1995 XJ Cherokee
replaced flywheel with the one from the 97 which belongs in it
broke map sensor pulling engine so maybe why it wouldnt start
or my timing is still off set it up as book says but it always drops in like 1 or 2 teeth past bolt hole i clamed dist down and still no start any suggestions
map sensor first then fine tune timing?
JDiMassi is offline
post #12 of 14 Old 01-26-2009, 06:45 PM
Socaljeep1
Socaljeep1's Avatar
My brother in-law had a similar problem in his YJ. Turned out to be the fuel relays (2).
Socaljeep
Go to Heaven for the climate, Hell for the company.
Mark Twain
/l ,[____],
l---L-OlllllllO-
()_) ()_)-o-)_)
Socaljeep1 is offline
post #13 of 14 Old 02-06-2009, 03:36 PM Thread Starter
JDiMassi
1995 XJ Cherokee
ok put in map sensor still not working
i checked the door sticker and it was mfg 2/96 that makes it a 96?
or a 97?
because theres different part numbers between 95 and 97 want to make sure we have the right parts on there because it should have fired by now im only unsure of the crank and distributor pickup right now so i dont know this jeep is turning into a nightmare
dont see anything for a 96 jeep wrangler so maybe its a 95?
JDiMassi is offline
post #14 of 14 Old 02-10-2009, 06:32 PM Thread Starter
JDiMassi
1995 XJ Cherokee
THE TRUCK IS DONE AND OUT OF MY SHOP THANKS TO ALL WHO CONTRIBUTED I APPRECIATE IT ALOT
the truck was a 97 as they made them with the redeisgn as early at jan of 96 i guess
i got the timing set up and once the lifters primed up and all the old gas in the injectors and carbon and such burned off the motor ran like a top and ran good real good i buttoned it up and delived it to the customer so we dont have to see it thank again guys
TOPICCCCC CLOSED haha
JDiMassi is offline
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 09:26 AM
1997 Jeep Wrangler--stumbling!! Wranglergirl_co TJ Wrangler Technical Forum 3 05-24-2009 03:29 AM
1997 Jeep Wrangler 2.5L 4 cyl... JeepMan905 TJ Wrangler Technical Forum 11 05-31-2007 02:24 PM
Problems with my 1997 Jeep Wrangler SE. PLEASE HELP! acleme1 TJ Wrangler Technical Forum 17 04-03-2007 10:02 PM
Jeep Wrangler 1997 problem jappe TJ Wrangler Technical Forum 30 01-02-2006 09:42 PM
