1997 Jeep Diesel misc stuff - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 1997 Jeep Diesel misc stuff
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 02-10-2016, 11:06 PM   #1
Triplemaxxx
Ok, so a little back ground. I put together a 1970 DJ postal Right hand drive Jeep. It had a 4cyl Mercedes diesel/ax15 5 speed/dana300. Well after a lot of money and time, the Jeep wasn't practical because its a postal basically. Skipping a lot of detail...I knew I just needed a newer jeep as a starting point and knew I wanted round headlights lol. Don't tell the YJ guys I said that! Ok on with my post!
My basic goal is to have the transmission back bone stock. I have a 4cyl ax5 now. So I am stealing the ax15 and adapter from postal jeep. I have a om617 5cyl diesel. Some questions I have are:
Is the transmission cross bar the same between 4cyl and 6cyl models?
Is the driveshaft the same between 4 and 6 cyl models?
About the transfer case.....NP231...my 4 banger won't work correct?21 vs 23 spline right?
Any other thoughts are always welcome and if you know of someone or someone on this board that has done this diesel swap, let me know please. Just have random questions. Ive been down this road with my last jeep but any helpful insight just saves time. On my postal, I had no help and everything was trial and error since no one had done it to a postal jeep. Figure this time around id rather not reinvent the wheel
Triplemaxxx is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 04:04 AM   #2
mukluk
If by transmission cross bar you mean transfer case skid plate, yes they're the same. The skid changed to a deeper design with different mount hole offset in 2002 (AKA the "shovel" skid plate).
The front driveshafts for the stick shift are both the same I believe, the auto uses a slightly skinnier version in order to clear the trans. The rear driveshafts vary slightly in length, depending on the rear axle installed.
The 231 for the 4.0L (manual and auto) and the 2.5L w/auto used a 23 spline input, the 4 banger w/AX5 used a 21 spline. There are also some differences as to the length of the input as well depending on what year the case came out of if I recall correctly, a search on the subject should show up better details.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 08:03 PM   #3
Triplemaxxx
Thank you, that is what I needed! I can prepare with 2 of the 3 and then when motor and trans is all done, ill figure out the driveshaft. Thanks again!
