1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler?
#1 | |
I bought my Jeep Wrangler new back in 1997 with a 2.5 Liter engine. I would like more power the four banger just is not working for me anymore. A couple years ago I bought a 1997 Jeep Cherokee to be my highway Jeep and the body is starting to go but the engine and transmission are the same. I was wondering if anyone knew if I could swap the 4.0 out of my Cherokee into my Wrangler. I know I am going to have to put in new drive shafts, but I did not know if the motor and transmission mounts are similar or the same?
#2 |
Jeep actually has a 4cyl frame and a 6cyl frame from the factory. You have to cut the 4 cyl mounts off and weld new mounts on for the 6cyl. Also, the steering bracket will need to be swapped from another 6 cyl TJ, not sure if the Cherokee one will work
2007 Rubicon Unlimited SRT8 6.1L Swap Auto RE 4.5" Long Arm 37" Cooper STT MT 17" Rims Currie G2 D60 Rear, ARB 5.13 Mopar bumpers rear DVD, LockPick, MyGig, Sirius, Full Soft Doors TMD Hood 2005 Inifinti G35 4 Door 6MT Stillen Stage 3 Supercharger |
#3 |
Junior Member
kinda have the same problem, i am looking into a wrangler but only a 4cyl and i have a 98 grand chrokee larado and i would see if i could switch the engine, though the wrangler would be a 5 speed and the cherokee is a auto.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
