1995 yj engine in 1997 tj???need help asap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 1995 yj engine in 1997 tj???need help asap
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 11-08-2012, 04:13 PM   #1
jeeperjoe7691
My buddy and i just bought a 1997 tj, the guy said he overheated and blew the head gasket, i replaced the gasket re seated the valves and put all new top end gaskets on (like i should do) and all torque specs were exact, still very low compression... this is beyond the point... i have a 2.5 liter 4 cylinder liked up for $300 but my jeep is a 1997 2.5 4 cylinder. WILL THIS WORK FOR A SWAP??? i have heard from several that it will be fine i know that obd2 emissions started in 1996 but is there a difference in the engines or can i just throw the intake manifold and accessories from my '97 onto the '95 engine and be good to go
jeeperjoe7691 is offline   Reply With Quote Quick reply to this message
2.5 liter , 4 cylinder , motor swap , tj , yj engine swap motor
