1988 Wagoneer D44 axles on my TJ - JeepForum.com
post #1 of 12 Old 09-22-2009, 02:01 AM Thread Starter
BigJoshStud
I have the oppurtunity to get some Waggy D44's for cheap and was wondering what are the advantages/disadvantages of adapting these axles to fit on my 1998 TJ?
I'm no pig... but I'm definately an ANIMAL!!!
BigJoshStud is offline
post #2 of 12 Old 09-22-2009, 03:33 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Too wide and too much work.
TheBoogieman is offline
post #3 of 12 Old 09-22-2009, 07:37 AM
DBLJ
DBLJ's Avatar
Your just a giant ray of sunshine this morning aren't you.
Op its just like any axle swap. Cut old brackets off and mount new ones among other stuff.
DBLJ is offline
post #4 of 12 Old 09-22-2009, 07:49 AM
BarneyJEEP
are they narrow track or wide track?
pass drop or driver drop?
what year truck did they come out of?
BarneyJEEP is offline
post #5 of 12 Old 09-22-2009, 07:55 AM
Brads_nky_yj
What are you talking about? They are the same width as his stock axles (might be .5" - 1" wider or narrower - mine are .5" wider than stock). They are great axles to swap in. Yes they have their limits, but are still a great choice. And as stated above, the same things are required to put them in your TJ as any axle swap. Grind, clean, prep, measure, measure, measure, weld, paint, install.
93 YJ - SOLD
Brads_nky_yj is offline
post #6 of 12 Old 09-22-2009, 09:23 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
they are 6-lug axles, you'll need new wheels too.
read here:
http://www.jeepforum.com/forum/f57/f...cation-777253/
According to that they are narrow track axles & a drivers side drop front. WMS: WMS
Looks like the front is fine (60.5"), rear will be too narrow (58.5").
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 12 Old 09-22-2009, 10:05 AM Thread Starter
BigJoshStud
From what I'm told they are drivers drop, 3:53, high pinion front, Low Pinion rear, Rear brakes and slightly wider than 60"... any forsee-able issues?
post #8 of 12 Old 09-22-2009, 10:07 AM Thread Starter
BigJoshStud
and came out of a 1988 Waggy
post #9 of 12 Old 09-22-2009, 10:11 AM
BarneyJEEP
if its HP front, it didnt come from a waggy
post #10 of 12 Old 09-22-2009, 11:40 AM Thread Starter
BigJoshStud
Sorry, got that backwards... here is what it says on craigslist:
Pair of D44's HP Rear LP Front (rear is LSD 90% sure of this, can pull the cover if you really want to know) out of an 88 Waggy- $200 for the pair
Parting out 1989 Jeep Wrangler
post #11 of 12 Old 09-22-2009, 11:48 AM
Unlimited04
Waggy's never came with a high pinion rear axle. they will both be LP.
Useful Write-Ups:
Funny:
post #12 of 12 Old 09-22-2009, 12:16 PM Thread Starter
BigJoshStud
after much number crunching it's really coming down to whether I should just by some bolt on rubicon axles and be done with it.... I think that's what I will do...
76 wagoneer(d44) axles jkm211 YJ Wrangler Technical Forum 6 01-01-2009 07:17 PM
80 Wagoneer Axles? Jesta YJ Wrangler Technical Forum 28 11-15-2007 07:18 PM
84 wagoneer axles Allen52105 TJ Wrangler Technical Forum 1 08-18-2007 10:34 PM
?? about Wagoneer axles 98formulaLS1 YJ Wrangler Technical Forum 6 03-19-2007 01:47 PM
Wagoneer Axles?? Hokie_YJ YJ Wrangler Technical Forum 9 02-01-2005 09:03 PM
