17MM , why the heck is it so hard to find... - JeepForum.com
post #1 of 26 Old 11-17-2012, 05:15 PM Thread Starter
evan1395
So I got my 2 quarts of Royal Purple SynchroMax fluid for the NV3550. I read I needed a 17MM Hex bit for both the drain AND fill plug. Out of the 3 autoparts stores my town has (Autozone,Oriellys, and Napa) not one of them had this bit in stock and on the shelves. Turns out only NAPA could order it for me.
Needless to say $19.48 later I obtained the part through them, should be here on Monday. Why is this such a specialty bit? I know it's a good size allen, but still! I went to 2 local hardware stores as well, the biggest size everyone carried was a 10mm -.-
Just thought i'd vent!
-Evan
P.S- Any tips for re-routing the oil when draining it so it doesnt puddle up on the skid plate? I really don't want to take it off.
evan1395 is offline
post #2 of 26 Old 11-17-2012, 05:20 PM
88hatchy
You could have called SnapOn/Matco/MAC and asked for the number of one of their local tool reps. I'm positive one of them would have it.
-Will
1997 TJ - Current project: Simple-ish build
88hatchy is offline
post #3 of 26 Old 11-17-2012, 05:23 PM
sduncan
sduncan's Avatar
ummmm....I made one once..I took a 6 in long metric bolt with a 17mm head on it, put it in the vice, applied a little heat, gave it a 90* bend and was done. In fact I still have it in my box somewhere....Cost about $2 at the time....
'98 TJ, 5.7 HEMI,
sduncan is offline
post #4 of 26 Old 11-17-2012, 05:25 PM
rubidriver
You can find a 3 pack (14mm, 17mm and another that I don't remember) on the rack at every Autozone in Texas, not sure about Cali. And I wouldn't recommend making one. There is a lot of extension on the bolt and when I tried doing that the bolt broke. Get you a set, you will use it more than once.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #5 of 26 Old 11-17-2012, 05:30 PM
sduncan
sduncan's Avatar
Iguess I should have been a little bit more clear..Just because no one had the exact tool you were looking for doesn't mean that you are completely screwed...Its an idea that can be used in a pinch....like a Sunday nite and no on has one and you need it to get to work the next day type thing. I probably used the thing once..maybe twice. I do have a real 17MM hex in the box too and much prefer it to a bent bolt.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #6 of 26 Old 11-17-2012, 05:33 PM
wushaw
Rockin jeep
wushaw's Avatar
I bought mine 15 years ago off the Snap-on truck for a NV3500 in a GM 1/2 ton, he had it in stock, no idea what it cost either.
wushaw is offline
post #7 of 26 Old 11-17-2012, 05:58 PM
Yams
It shouldn't get onto the skid. Only the t-case would cause problems.
Yams is offline
post #8 of 26 Old 11-17-2012, 06:29 PM
joeyk803c
The hex socket set had the 17mm in it. IIRC you can get them for like under $15. I used mine when I changed the fluids in my nv3350
joeyk803c is offline
post #9 of 26 Old 11-17-2012, 06:46 PM Thread Starter
evan1395
Here in Cali at the Autzone's even in their little combo packs, they only went to 10mm's.
evan1395 is offline
post #10 of 26 Old 11-17-2012, 09:09 PM
Yellow02
I made mine with a bolt, locktite and 3 nuts. Free from what I had laying around.
USN Jeep Club Hull #144
#83 Rubicon Sahara Edition
Yellow02 is offline
post #11 of 26 Old 11-17-2012, 09:21 PM
MooSe7
tooltopia.com is a good resource for tools.
2004 Wrangler Sport
2006 Grand Cherokee Laredo
MooSe7 is offline
post #12 of 26 Old 11-17-2012, 09:24 PM
synolimit
2010 XK Commander
Made mine too. Well not really i have a bunch of bolts laying around. Just used the head of one and a pipe wrench. Works every time for free.
synolimit is offline
post #13 of 26 Old 11-17-2012, 09:26 PM
jkp
Sears has them.
'92 Islander
'06 Rubicon
jkp is offline
post #14 of 26 Old 11-17-2012, 09:26 PM
Cuder
I bought mine at Sears for $12.
My Build Thread:
Cuder is offline
post #15 of 26 Old 11-17-2012, 09:28 PM
Cuder
Originally Posted by jkp View Post
Sears has them.
Jinx, you owe me a coke.
My Build Thread:
Cuder is offline
