16x8 rim with 5" BS. Can I run a 285/75/16? - JeepForum.com
post #1 of 6 Old 04-24-2013, 06:24 AM Thread Starter
terpsmandan
2009 JK Wrangler
Title says it all. Planning 3" lift.
terpsmandan is offline
post #2 of 6 Old 04-24-2013, 06:41 AM
tyvanwie
Sure
Sent from my iForum using JeepPhone
tyvanwie is offline
post #3 of 6 Old 04-24-2013, 06:47 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
That backspacing is cutting it too close for me.
32.8x11.2/16".
TheBoogieman is offline
post #4 of 6 Old 04-24-2013, 03:47 PM
Gary2
Thats exactly what I run and have not had an issue . If you have the correct bracket extension on your rear axle for the track bar keeping it close to the stock angle, you should be fine . Keeping your rear track bar as flat as possible keeps the left and right motion of the axle to a minimum so you wont have a rub on the spring mounts . In the front some say to add a washer or two to extend the steering stops if you can stop yourself from turning the wheels far enough to rub the OE control arms. I have no rub on my aftermarket arms.
Gary2 is offline
post #5 of 6 Old 04-24-2013, 04:15 PM
J03_TJ
I went through a set of tires with that setup without any problems. For grins I put my 315/70/16 tires on without my wheel spacers and they fit, but it was too close for me to be comfortable with on the 315 size.
J03_TJ is offline
post #6 of 6 Old 04-29-2013, 04:29 PM Thread Starter
terpsmandan
2009 JK Wrangler
Thanks to all.
