160 degree thermostat - what's the point? - JeepForum.com
post #1 of 43 Old 10-28-2009, 12:00 PM Thread Starter
tsteiden
Been trying to figure out why my 98 TJ won't get very hot. I thought the thermostat was stuck open, but discovered a 160 degree thermostat installed instead of the (apparently) OEM 192 degree.
I'm going to change it back so I can get some heat, but why was it changed to 160 to begin with? Has this been stealing mileage by running too cool? I'm a little worried about changing to 192 because I may discover why it was changed to begin with. Could it just be a regional thing?
I hate surprises. Ideas? Answers?
tsteiden is offline
post #2 of 43 Old 10-28-2009, 12:03 PM
TheBoogieman
Jeepaholic
TheBoogieman's Avatar
You should never go below the OEM thermostat temp range.I thought it was 185.Maybe they thought it would make the engine last longer.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #3 of 43 Old 10-28-2009, 12:07 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
OEM is a 195*
GOLENJEEPTJ is offline
post #4 of 43 Old 10-28-2009, 12:13 PM
JBTJ
Owner before you probably thought it would help, which it won't. Just put in the 195 degree stat that's what the motor likes. Don't worry about it. It will be fine.
JBTJ is offline
post #5 of 43 Old 10-28-2009, 12:16 PM
cyberiv
I thought the purpose of a low temp thermostat in theory was to run the engine a little cooler to slightly increase the power, but that for it to be effective you needed a programmer to let the ecu know...then again i am more familiar with using them in sports car apps, not a jeep...
cyberiv is offline
post #6 of 43 Old 10-28-2009, 12:16 PM
TheBoogieman
Jeepaholic
Originally Posted by GOLENJEEPTJ View Post
OEM is a 195*
I stand corrected by you(as usual).I'll be over for Halloween for a visit.
post #7 of 43 Old 10-28-2009, 01:18 PM Thread Starter
tsteiden
Good answers - you are right - it's 195 - that should warm things up a bit in the cab!
tsteiden is offline
post #8 of 43 Old 10-28-2009, 01:31 PM
spdnjoe
I run a 180 in mine. A 180 thermostat still lets the engine run around 195 which the computer is still happy with and keeps me at around 1/4 on the temp gauge. I just like the fact that if things start to heat up, I have a little more cushion before it goes into the red. Plus, I still have plenty of heat. just my .02
spdnjoe is offline
post #9 of 43 Old 10-28-2009, 01:39 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I think you would be better off with the factory recommended 195*.
MPG will be better.
Emissions will be better.
Your oil will stay cleaner.
Wheelin98TJ is offline
post #10 of 43 Old 10-28-2009, 01:42 PM
fishinjeeper
my neighbor was telling me how he took them out of this vehicles so they wouldn't over heat. i laughed...
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #11 of 43 Old 10-28-2009, 01:44 PM
spdnjoe
I get 17-19 mpg on the highway and I just passed California emissions 2 weeks ago.
I've done this with every offroad vehicle and tow vehicle I've owned in the last 15-20 years and have never had an issue.
Everyone has there own opinion and views, I'm not saying mine is right or wrong, I'm just telling you what I did to mine and it's fine.
spdnjoe is offline
post #12 of 43 Old 10-28-2009, 01:45 PM
NotURMailman
NotURMailman's Avatar
Most likely the t-stat went bad on the PO and he didn't know any better, or let some kid at the parts store talk him into the cooler one.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #13 of 43 Old 10-28-2009, 01:47 PM
Wheelin98TJ
JEEP FREAK
No problem, we disagree on this.
I tried a 180 t-stat in my TJ for some time, but I eventually went back to the 195. I did not see any benefits with the 180 t-stat. It only made things worse for me.
post #14 of 43 Old 10-28-2009, 01:51 PM
spdnjoe
no worries my friend.
It's all good. The nice thing of a forum is that people can post their opinions and don't have to take things personally. It's just a persons opinion.
spdnjoe is offline
post #15 of 43 Old 10-28-2009, 02:04 PM Thread Starter
tsteiden
I'm glad to know there are options - If I lived in CA like my fortunate friend, 160 would be a go for me too, but my friend in Michigan says 180 - that makes sense too. I don't really stress the thing too much and not freezing is high on my list here in the midwest so the 195 OEM is probably my choice.
tsteiden is offline
180 degree thermostat dimaxxxl TJ Wrangler Technical Forum 11 09-18-2007 09:49 PM
160 degree thermostat BORY TJ Wrangler Technical Forum 6 07-12-2007 05:32 PM
What degree thermostat do you use? paultyler YJ Wrangler Technical Forum 21 10-09-2006 12:22 PM
What is the original equipment thermostat degree? scorpionkill TJ Wrangler Technical Forum 1 11-03-2005 09:57 AM
160 Degree Thermostat JFiorentino TJ Wrangler Technical Forum 4 04-25-2004 01:11 PM
