15'' or 16'' on the rubi - JeepForum.com
post #1 of 7 Old 07-03-2010, 02:44 PM Thread Starter
FAW-CAN-ADIAN
well,im gettin ready to lift the jeep.its an 04 rubicon.im going with a 3"suspension lift for now.bds was the first choice but maybe zone??apperantly these companies are the same??but my question is tires.i was planning on 285/75/16 on my stock moabs but ive been told the will rub without spacers.i dont really want spacers.should i just buy 33/12.5/15 tires and new wheels with a better offset??15" tires are a bit cheaper and they will fit?...i figure i could always sell the moabs and tires.oh...i guess tires would go from load range e to c.better or worse??
FAW-CAN-ADIAN is offline
post #2 of 7 Old 07-03-2010, 03:06 PM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
I've done both with wheel spacers and aftermarket wheels with less backspacing.Metric sized tires are much more expensive.RC makes some really good wheel spacers for under $120.It's up to you.
TheBoogieman is offline
post #3 of 7 Old 07-03-2010, 03:20 PM
TJDaveX
My vote is for 15" wheels and tires. Cheaper, and softer ride with more choices of tires with a "C" load rating.
Plus, you will have no problem selling your Rubi Moab take-offs. They are sought after by owners of Cherocars, Liberty's, YJ's and non-Rubi TJ's. I even bought a set of Rubi Moabs and tires to run in the winter when my Jeep was a daily driver. When I was done with them, I had no problem selling them for what I bought them for.
TJDaveX is offline
post #4 of 7 Old 07-03-2010, 03:24 PM
VanBCguy
What about the simple (and VERY cheap) idea of just a steering stop adjustment to prevent rubbing at full turn? Or are you being told they'll rub even at a straight line?
VanBCguy is offline
post #5 of 7 Old 07-03-2010, 03:39 PM Thread Starter
FAW-CAN-ADIAN
actually....i was told the inside sidewall would rub on the rear coil pads.i want to run either a trxus mt or a goodyear mtr.i want something around 33'' tall and around 10.5 or so wide.i honestly dont really like the rubi wheels...just really cant afford wheels but only want to do this once.what are my moabs with new tires worth?
post #6 of 7 Old 07-03-2010, 03:43 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
My '04 Rubicon has 15" aluminum wheels and I would always go for 15" over 16". Tire and wheel choices are far more plentiful and less costly for 15". I would also go for aftermarket 15" wheels before I'd install spacers.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #7 of 7 Old 07-03-2010, 03:47 PM
VanBCguy
Not dismiss anything you're saying Jerry, but both the OP and I being here in BC Canada, so it makes for a different market. Most of the guys I know run 16's. That would make me think that the 16" wheels and 16" tires would be more plentiful up here.
To the OP: where in BC are you?
VanBCguy is offline
wheel , wheel size , rubicon
Rubi shocks when changing to rubi springs? DocJake JK Wrangler Technical Forum 1 10-13-2009 08:36 PM
Rubi D44 thick gear in a non Rubi D44? mobyjeep TJ Wrangler Technical Forum 11 07-05-2009 05:00 PM
Rear Rubi locker in front Rubi axle. NotURMailman TJ Wrangler Technical Forum 4 05-08-2009 10:56 PM
Need to know Stock 05 Rubi Shock Lengths (Rancho 2.5" shocks on stock Rubi) jtice TJ Wrangler Technical Forum 2 09-24-2008 10:45 AM
getting rubi lockers to work in a non-rubi got_4_lo TJ Wrangler Technical Forum 1 06-10-2006 05:25 AM
