10" Wheel backspacing? - JeepForum.com
post #1 of 20 Old 06-24-2013, 12:49 PM Thread Starter
mnm99
Looking to go with 33/12.5/15's. I know they could fit on a 8" wheel and the backspacing would be around 4". What backspacing should I use on a 10" and also keeping them tucked in at tight as possible? Looking at going with the Soft 8's.
Thanks
mnm99 is offline
post #2 of 20 Old 06-24-2013, 12:57 PM
NotURMailman
NotURMailman's Avatar
You don't want to go over 4" BS, it doesn't matter how wide the wheel is.
With a 10" wheel there will be no tucking.
I am in the process of removing the 10" wheels from my Jeep.
Atleast twice that I can think of, I attempted to follw the othe TJs in my club down some narrow trails and ended up with my rear tires wedged between a rock wall and a tree.
It was a good laugh for everyone, until a JK joined our group. I then dubbed his Jeep "The Fat Chic" and it stuck.
But, that wasn't the point.
Why do you want 10" wheels?
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 20 Old 06-24-2013, 01:32 PM
stump1
3.75 is standard i believe for the 15x10's
i had 8's and went 10's weeks later
i dont air down to single digits and i like the look alot better so it worked for me
MY RIG: http://i78.photobucket.com/albums/j87/ramburger/a0fcb769-5e55-4a62-8426-cb7cce41c0c2_zpsccea3c78.jpg
stump1 is offline
post #4 of 20 Old 06-24-2013, 01:51 PM Thread Starter
mnm99
I figured the 12.5 wide tire would fit better on a 10. I'd really like to keep the stock wheels I have, but it looks like the widest I can go with is 10.5. So I figured if I have to get new wheels 10 would be better.
mnm99 is offline
post #5 of 20 Old 06-24-2013, 01:53 PM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
Don't listen to NotURMailman,unless he actually IS your mailman(I heard his wife is on crack JK!).I ran 10" wheels with 4" backspacing with 33's and they stuck out over 3"s.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #6 of 20 Old 06-24-2013, 01:59 PM
NotURMailman
You're so confusing...
You just said not to listen to me and then repeated what I said in different words.
10" wheels are not going to "tuck". That's all there is to it. 12.50s fit fine on 8" wheels.
post #7 of 20 Old 06-24-2013, 02:04 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You could use wheel spacers and keep your stock wheels.
With wheel spacers, you'll have enough room for 12.50 wide tires.
Wheelin98TJ is offline
post #8 of 20 Old 06-24-2013, 02:24 PM Thread Starter
mnm99
I know. I go back and forth with that. I'm concerned about the safety of them. Also New Soft 8's are around $250. Wheel spacers are around the same.
mnm99 is offline
post #9 of 20 Old 06-24-2013, 02:28 PM
NotURMailman
Yes, but then you have steel wheels.
post #10 of 20 Old 06-24-2013, 02:31 PM
biffgnar
biffgnar's Avatar
Quality spacers properly installed are fine. OEM wheels much higher quality wheel than steel soft 8s.
biffgnar is online now
post #11 of 20 Old 06-24-2013, 03:08 PM Thread Starter
mnm99
Yea.... SO I'm guessing Spidermax spacers? Or are something like this http://www.summitracing.com/parts/aa...4123/overview/ with longer studs? What would be stronger. $100 vs $200
mnm99 is offline
post #12 of 20 Old 06-24-2013, 03:25 PM
biffgnar
biffgnar's Avatar
You want spidertrax style not those in the link.
post #13 of 20 Old 06-24-2013, 04:11 PM
99_TJ_Wyoming
I've been running RC spacers (same style as Spidertrax) for over 2 years and have never had an issue, I use blue thread locker on the spacer nuts and torque the lug nuts normally.
99_TJ_Wyoming is offline
post #14 of 20 Old 06-24-2013, 05:56 PM
chopperkid2000
A little kicker, most manufacturers will not warrant a 12.5" tire on an 8" wheel.
chopperkid2000 is offline
post #15 of 20 Old 06-24-2013, 06:10 PM
CharlieHo
I've never had the impression that any tire had a warranty, period.
Originally Posted by mdm
You could ask it nicely to move over. When that doesn't work, get a bar or 2x4 and ask it again.
I have the ability to spell correctly, it's just that the autocorrect on my iPad will not permit it.
CharlieHo is offline
