10 bucks worth of aluminum - Page 7 - JeepForum.com
post #91 of 272 Old 07-14-2010, 03:14 PM
anymanusa
I believe aluminum to be a poor choice of material for a caliper bracket. For the prototype and fitment, yeah sure, but I wouldn't install an al bracket on any of my vehicles, and non of them came with al either. My vette does have an al caliper, but the brackets are steel.
anymanusa is offline
post #92 of 272 Old 07-14-2010, 03:31 PM
lumpster
lumpster's Avatar
maybe, The only thing i would worry about with aluminum is the bracket not staying tight. Steel might take longer to machine but it might still be worth it, and a hog end mill can cut fairly fast. You could always have the piece cast and then finish mill it if you make enough of them.
lumpster is offline
post #93 of 272 Old 07-14-2010, 03:33 PM
EricRollerSkate
Ironically, I believe the corvette ZR1 and Z06 both have a frames made of...you guessed it...aluminum. Not argueing, just saying.
Lowered, Dubbed, and Spinning
Why wear a flip flop on your left foot, and a steel toe on the right?
EricRollerSkate is offline
post #94 of 272 Old 07-14-2010, 03:47 PM
lumpster
lumpster's Avatar
your comparing apples to oranges.
lumpster is offline
post #95 of 272 Old 07-14-2010, 03:50 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Any specific reason(s)?
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #96 of 272 Old 07-14-2010, 03:59 PM
EricRollerSkate
You leave fruit out of this!!
I actually agree with both of your comments.
I just thought it was mildly ironic he mentioned his vette having steel caliper brackets, but some vettes have entire frames made of aluminum. I find many things ironic that actually just aren't. sometimes.....ironic.
post #97 of 272 Old 07-14-2010, 04:00 PM
EricRollerSkate
Weaker.
post #98 of 272 Old 07-14-2010, 04:00 PM
DaleII
Especially is it's made from 6061 T6 aluminum.
2005 Silver LJ
DaleII is offline
post #99 of 272 Old 07-14-2010, 04:06 PM
rlockwood
steel is always stronger, and thats not the question.. is aluminum strong enough? thats all that matters..
rlockwood is offline
post #100 of 272 Old 07-14-2010, 04:08 PM
EricRollerSkate
ESPECIALLY, if it's made from medium strength 6061 T6.
post #101 of 272 Old 07-14-2010, 04:19 PM Thread Starter
mrblaine
Wizard of Brakes
mrblaine's Avatar
Nope, not always.
Yep, that's all that matters. Is the selection of material adequate in the application it's being used in?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #102 of 272 Old 07-14-2010, 04:19 PM
RubiconRazorbac
Weaker.
Weaker how? Significant enough to make a difference in this application?
The question is whether the material will hold up in the application. Hell, there's always SOMETHING out there stronger.
There you go...
2003 TJ Rubicon:
2017 JKU Rubicon:
post #103 of 272 Old 07-14-2010, 04:20 PM Thread Starter
mrblaine
Wizard of Brakes
mrblaine's Avatar
You tickle my funny bone. What's even sillier is my steel caliper brackets on my front aluminum steering knuckles.
I am Savvy
mrblaine is offline
post #104 of 272 Old 07-14-2010, 04:30 PM
DaleII
On top of the aluminum differential housing?
2005 Silver LJ
DaleII is offline
post #105 of 272 Old 07-14-2010, 04:37 PM
JeepFund
1982 CJ7
What's the steel/aluminum cost difference though? (I don't purchase the stuff)
-JeepFund
ΞlllllllΞ
JeepFund is offline
aluminum , brake caliper bracket , centeric premium calipers , savvy , vanco super 17
Rhino Lining inside of jeep? Worth 6-800 bucks? dfaircloth88 TJ Wrangler Technical Forum 42 02-01-2012 04:23 AM
Is the Atlas 4-speed worth an extra thousand bucks to you? MattTheMudder TJ Wrangler Technical Forum 9 05-08-2010 09:28 PM
127-130....104-105 is it worth 50 bucks? slowassjeep TJ Wrangler Technical Forum 12 09-19-2005 04:47 AM
Brand New but with 4000 bucks worth of damage. Ol'Blue Jeep TJ Wrangler Technical Forum 35 08-27-2005 09:26 AM
s3t worth the 500-600 extra bucks over the 3t? UNCCPikeTJ TJ Wrangler Technical Forum 1 07-19-2003 10:39 PM
