Quantcast 1-ton steering DONE! *pics* - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 1-ton steering DONE! *pics*
Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
Old 04-29-2008, 11:31 PM   #1
RYANSTULC
Well, after waffling the stock tie-rod, and discovering my HPD44 was "odd", I set about to finally fix my front end. My D44 front end had D30 knuckles, but retained the D44 center section. This made my turning radius horrible, as the tie-rod hit the diff cover, and rubbed the track-bar bracket.
So I scored some Chevy D44 knuckles, and had them powder-coated.
Let the fun begin.
Teardown:
Passenger side:
Driver side:
Riddler diff cover:
1/4" wall DOM tie-rod
Removed the steering stabilizer braket, and welded the front solid for future ram mount location
mock-up
TRE's are 1-ton chevy. 7/8 x 18TPI. Solid.
RYANSTULC is offline   Reply With Quote
Old 04-29-2008, 11:38 PM   #2
RYANSTULC
More....
Tight clearance, but it works great.
Length of drag-link is almost identical to that of the track-bar. And they are damn-near parallel.
Pitman arm from a '91 trans-am
In conclusion, tonight I drove home from the shop at speeds up to 70 MPH.
Absolutely no bump-steer, no death-wobble, and it tracks straight and true.
Also, there's no stabilizer at all. Steers with one finger on the steering wheel at highway speeds.
I'm happy, and I owe a huge thanks to my friend Brad. He's the mastermind behind this project.
Old 04-29-2008, 11:50 PM   #3
Unlimited04
Unlimited04's Avatar
so what is the parts list on the front axle?
I'm seeing HP D44 - from what truck?
Chromo shafts (nice!)
'91 trans am pitman arm
Chevy D44 knuckles (flat tops?)
what is your WMS to WMS and bolt pattern? Did you do some shortening or retrofitting here? what brake rotors and calipers?
Unlimited04 is offline   Reply With Quote
Old 04-29-2008, 11:55 PM   #4
RYANSTULC
Not sure from what truck, but Foothills 4x4 made the axle a few years ago for the PO.
Warn Chromo Shafts
'91 trans am pitman arm ( stock arm wasn't long enough to allow for true 8" steering )
Chevy D44 knuckles (pass side is flat top),,,but after assembly, I don't need any more "high steer"
The tie rod now is about 4" higher than stock.
I'm not sure of the WMS dimension.
Bolt pattern is 5 on 5.5
Editted: Foothills 4x4 out of Cali. made the axles.
Old 04-29-2008, 11:58 PM   #5
bman9089
You get what you pay for
bman9089's Avatar
very nice work. rocks don't stand a chance.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
† Christian Jeep Club †
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline   Reply With Quote
Old 04-30-2008, 12:04 AM   #6
RYANSTULC
Brake rotors / calipers are off an '87 chevy 1/2 ton.
I also replaced the calipers tonights as well. The driver's side was sticking slightly.
Pads and rotors didn't need replacing yet.
I can't wait to get my ram mounted and tap the box.
Old 04-30-2008, 10:46 AM   #7
RYANSTULC
Question:
Those of you with hydro assist; Are you using a bigger resevoir?
I'm planning on running a 1 1/2" x 8" ram from PSC.
Old 04-30-2008, 01:01 PM   #8
Unlimited04
Originally Posted by RYANSTULC View Post
Question:
if i remember correctly, most of the ram setups i've seen are using a Saginaw pump (older CJ style) or a PSC pump with remote reservoir to make sure you're getting enough power. don't forget the power steering cooler
here's a writeup - different brand but same idea, but it is a YJ, so it may have a saginaw pump: http://www.jeeps-offroad.com/articles/redneck.php
Old 04-30-2008, 01:03 PM   #9
Luke4554
Warn Chromo Shafts
Educate me on this .. True 8" steering? Did you change the pitman arm so your steering wheel is shorter lock to lock ? Im assuming thats what its for, for running larger tires so you dont have to feel like your driving a school bus. Am i remotely close ? If not let me know .. im just curious thats all.
Thanks!
[SIZE="1"][B]2000 TJ Sport[/B]
4.0L | 5spd | 4" SkyJacker | Soft 8's | 33" TRXUS | 30/35 | AA SYE/CV DS | SuperWinch | 4 KC's | Pure Bred Tube Fenders | EMPI Buckets | Novak Linkage| Pure Bred Bumpers | Bestop Tinted Soft Top & Bikini | HiLift | Yellow Top | Herculiner | JKS Discos | Skid Row Steering Skid
[b]Owner of [U]WWAutosports[/U] & [U]Pure Bred Fabrications[/U] Dayton, Oh[/b][/SIZE]
Luke4554 is offline   Reply With Quote
Old 04-30-2008, 01:21 PM   #10
RYANSTULC
The pitman arm length should match the length of the knuckle ( center of axle shaft to center of tie rod on the knuckle itself). These 2 lengths should match to maximize available steering. So by getting true D44 knuckles, I needed a longer pitman arm.
The 8" reference is the amount of travel the tie rod makes along a horizontal plane. ( from dead center the tie
rod travels 4" each way ) This allowed me to regain all my steering radius. The steering-stops on the knuckles
now actually make contact. I can finally make sharp turns.
Old 04-30-2008, 10:26 PM   #11
Luke4554
ic .. cool. How did you know that particular pitman arm would fit? is it a common application or did you just shop around.
Old 04-30-2008, 11:37 PM   #12
RYANSTULC
Luckily a friend has the same pitman arm, so I knew it would work.
Although trying to find this pitman arm on the internet was like looking for a unicorn.
I ended up getting the whole steering box and pitman arm from my local junk yard for cheap.
Need a steering box from a '91 trans-am?
Old 05-01-2008, 07:03 AM   #13
BoKnows
Like the riddler diff cover, nice paint job on it too. I have one on the rear and it has held up to some hard abuse
1997 TJ White
3speed auto, RE Long Arm with ACOS...5" of lift, 35x12.50 PC XAT on 15x8 wheels, Bilstein 5100 shocks, rubicon D44 with front and rear ARBs, AA SYE, Coast CV Driveshaft, 4.10 gearing, ORO Swayloc, ARB Snorkel and K&N filter, magnaflow exhaust, Fabtech front bumper, LoD Xpedition Rear bumper, LoD Rocker Guards, hella lights, 6" Xenon flares, HULA GIRL on dash...........she makes me smile
WWW.MILITARYJEEPERS.COM
WWW.WHEELERSFORTHEWOUNDED.ORG
BoKnows is offline   Reply With Quote
Old 05-01-2008, 01:14 PM   #14
Luke4554
Riddler covers are the shiznit .. anyone watch the utube destruction test they had on there? .. Granted it wasnt being tested in moab on rocks but still impressive non-the-less.
Luke
Old 05-01-2008, 01:18 PM   #15
imbezol
Have you tried stuffing the driver side front wheel to make sure the tie rod isn't going to hit the trackbar drop bracket?
imbezol is offline   Reply With Quote
Glock Forum
