1.25 inch spacers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 1.25 inch spacers
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 07-20-2014, 03:46 PM   #1
n21c
1.25 inch spacers
Just installed 1.25" spacers on my TJ, but the lugs to the spacers only went down half the lug due to spacers sitting on the factory lug bolts. I used blue lock tite on the lugs. Has anyone else seen this, do I have to get extra long lug bolts and press them in? Help, advise please, don't want my wheels coming off or snapping a bolt due to torque at the end of the bolt.
n21c is offline   Reply With Quote
Unread 07-20-2014, 04:18 PM   #2
kjmccar
Can you post pictures? Also, what brand? I just put some 1.25 on my jeep no problems. Finally, you should use loctite red for the nuts holding the spacers into the jeep/ rotors.
kjmccar is offline   Reply With Quote
Unread 07-20-2014, 05:58 PM   #3
JBTJ
JEEPer For Life
JBTJ's Avatar
You used the wrong type of spacers, and should not use loctight on your lug nuts. If you must use wheel spacers, this is a better type. http://www.jeep4x4center.com/wheel-a...eel-spacer.htm
JBTJ is offline   Reply With Quote
Unread 07-20-2014, 10:20 PM   #4
fratis
fratis's Avatar
Spydertrax includes thread locker with their spacers. Its been debated to death but they have the best install procedure. To the OP your description is hard to follow.
-insert meaningless out-of-place political diatribe-
fratis is offline   Reply With Quote
Unread 07-21-2014, 04:40 AM   #5
JBTJ
JEEPer For Life
JBTJ's Avatar
To hold the spacer on, but not on the lugs that hold the tire on.
Unread 07-21-2014, 11:40 AM   #6
fratis
fratis's Avatar
Yeah I'm not totally understanding what the OP has and what the problem is.
Unread 07-21-2014, 01:51 PM   #7
kjmccar
I have spidertrax spacers and I used the included loctite. I followed their directions to a tee because their primary concern (well, after making a profit) is safety - and that's why they have the best reputation for spacers. Whereas some other companies would rather make an affordable product than a reliable one.
And yes, I'm having a hard time. Please post pics so we can help you!
Unread 07-21-2014, 01:54 PM   #8
JBTJ
JEEPer For Life
JBTJ's Avatar
Originally Posted by kjmccar View Post
I have spidertrax spacers and I used the included loctite. I followed their directions to a tee because their primary concern (well, after making a profit) is safety.
With what? Thought you said you had no problems.
Unread 07-21-2014, 01:59 PM   #9
2jhanna
I have spidertrax spacers and I used the included loctite. I followed their directions to a tee because their primary concern (well, after making a profit) is safety. Whereas some other companies would rather make an affordable product than a reliable one.
He's having a hard time understanding the OP post?
jhanna
denton county, tx
2jhanna is offline   Reply With Quote
Unread 07-21-2014, 02:11 PM   #10
kjmccar
Yes, that's what I meant. Sorry. I'm on my cell phone - it's difficult to type.
Unread 07-21-2014, 03:21 PM   #11
n21c
Guys, I got these from eBay Integrity Automotive.
Manufacturer Part Number:
5450-5500B WHEEL SPACERS
Surface Finish:
6061 T6 ANODIZED ALUMINUM
Interchange Part Number:
5 lug 4.5 to 5 lug 5
Warranty:
Yes
Brand:
INTEGRITY-AUTOMOTIVE
Placement on Vehicle:
Left, Right, Front, Rear
Part Brand:
5 X 114.3 TO 5 X 127 WHEEL ADAPTERS
Unread 07-21-2014, 03:46 PM   #12
kjmccar
Originally Posted by n21c
Guys, I got these from eBay Integrity Automotive. Manufacturer Part Number: 5450-5500B WHEEL SPACERS Surface Finish: 6061 T6 ANODIZED ALUMINUM Interchange Part Number: 5 lug 4.5 to 5 lug 5 Warranty: Yes Brand: INTEGRITY-AUTOMOTIVE Placement on Vehicle: Left, Right, Front, Rear Part Brand: 5 X 114.3 TO 5 X 127 WHEEL ADAPTERS
Looks like you bought these http://www.ebay.com/itm/231018460369 which are 5x4.5 to a 5x5 bolt pattern. If you are trying to put your stock/old wheels back on this WONT work. You need a 5x4.5 to 5x4.5 bolt pattern. The ones you bought are essentially adapters. To a different bolt pattern.
Also, thanks for posting pics. I'm at work now, but I can take a look at them this evening
Unread 07-21-2014, 03:56 PM   #13
otisdog
Something's wrong - why are only two studs coming part way through the spacers? Your explanation of the problem is vague. This is what the spacers should look like. These are Spidertrax 1.25" spacers with a 5 x 4.5 bolt pattern.
03 Sport
otisdog is offline   Reply With Quote
Unread 07-21-2014, 03:59 PM   #14
kjmccar
Looks like there might be two untreated studs and three carbon steel studs giving the appearance that there's only two.
Unread 07-21-2014, 05:27 PM   #15
fratis
fratis's Avatar
Manufacturer could have machined the recesses deeper.
