1.25 or 1.5 Wheel Spacers - JeepForum.com
post #1 of 9 Old 11-14-2008, 06:53 AM Thread Starter
TimBrown
I know this topic has been covered many times and Iím sorry for the inevitable repost but the search didn't yield the results I was looking for. I am about to get some 305/70/16 (32.8 x12.01x16 according to the conversion) to go on my MOAB wheels in the very near future. I know I am going to need some wheel spacers so I donít have any rubbing issues. My question is, do I need 1.25 or 1.5 inch wheel spacers? Thanks for the help
TimBrown is offline
post #2 of 9 Old 11-14-2008, 07:14 AM
greenmachine99
greenmachine99's Avatar
1.25 is plenty. I ran 32's on my stock wheels without spacers and had no rubbing issues at all.
greenmachine99 is offline
post #3 of 9 Old 11-14-2008, 07:27 AM
04xrckmtn
I'm running 1.25 with 33x12.50's on stock wheels and have very little rubbing.
04xrckmtn is offline
post #4 of 9 Old 11-14-2008, 07:59 AM Thread Starter
TimBrown
What width are the tires, and are they on the MOAB wheels?
TimBrown is offline
post #5 of 9 Old 11-14-2008, 08:00 AM Thread Starter
TimBrown
What is the back spacing on the stock wheels?
TimBrown is offline
post #6 of 9 Old 11-14-2008, 08:28 AM
Scotch740
Scotch740's Avatar
I put 1.5" spacers on with my Ravines and still rub my control arms a little at full turn with 35"s.
Also with the 1.5" spacers I had to put on longer wheel studs in the D44 shafts. There wasn't enough engagement of the threads with the stock ones.
http://www.jeepforum.com/forum/f9/rear-d44-studs-too-short-wheel-spacers-592050/
Scotch740 is offline
post #7 of 9 Old 11-14-2008, 09:01 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Most stock wheels have 5.5" of backspacing with the only exception being Moabs (5") and Gamblers (5.25").
You could run up to 4.75" of backspacing and have enough room for 12" wide tires. You would rub slightly when turning full lock. If your axle is not centered, the rubbing will be worse in one direction.
The size of the side lugs on the tire is a factor in how much it will rub.
What type of lower control arms is another factor (many aftermarket arms give you a little more tire clearance).
If you want full turning radius lock to lock, I think 1" or 1.25" should be plenty for you.
Wheelin98TJ is offline
post #8 of 9 Old 11-14-2008, 11:28 AM
04xrckmtn
I believe my RME alcoa's have 5.25"
post #9 of 9 Old 11-14-2008, 03:11 PM
greenmachine99
The tires were 32x11.50. My backspacing was 5.5". Yours are 5.0" so you already have an extra .5". Either will work, id stick to the 1.25"s though.
Do wheel spacers make your steering wheel wobble at high speeds? bgndobe TJ Wrangler Technical Forum 22 07-20-2009 08:27 AM
Wheel spacers help!!! kingkong33 YJ Wrangler Technical Forum 3 06-01-2008 01:05 PM
Wheel spacers Borla87 YJ Wrangler Technical Forum 8 03-20-2007 04:49 PM
Wheel Spacers? Dugzilla TJ Wrangler Technical Forum 19 12-26-2006 04:03 PM
Wheel Spacers DonzRedTJ TJ Wrangler Technical Forum 17 05-21-2006 08:41 PM
