06flex's build (my build up) - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 06flex's build (my build up)
Savvy Billet LED Tail LightsFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Jeep Wrangler Complete Gear Upgrade Kits with Installs and
Unread 11-16-2007, 06:26 PM   #61
06flex
Originally Posted by rubicon35
looks good man. i did the mesa leds too. very pleased with the turnout. im in the middle of my build now too. just waiting for wheels have everything else. its a b**** waiting tho!
I hear ya. I have ran out of little things to do so now I have to wait on the lift and tires. Then I will be waiting on gears and a selectable locker for the rear. I guess it will never end. I am sure I will find some side projects like rockers,lunchbox locker for the front, and other mis. armor to keep me busy untill the tires and lift.
Stu website supporter. http://www.stu-offroad.com/
One of the best jeep websites out there for reference. If you can help please do.
http://www.stu-offroad.com/misc/environment.htm
You didn't correct the problem, you only worked around the real problem.
06flex is offline   Reply With Quote Quick reply to this message
Unread 11-16-2007, 08:55 PM   #62
LimeGreen
Awesome! Quick question, Can you show me a pick of the hole saw you used for the led's? Not sure what that looks like. Thanks
LimeGreen is offline   Reply With Quote Quick reply to this message
Unread 11-16-2007, 08:59 PM   #63
06flex
http://www.lowes.com/lowes/lkn?actio...72A&lpage=none
This is the one I used. If I had to do it again i would have used a 4.25" one and filed it out to fit. The 4.5" hole works just fine but it is not a real tight fit. It by no means is going anywhere but I always am looking for something better
Unread 11-16-2007, 09:26 PM   #64
plowe
Originally Posted by 06flex
I probaly will wheel maybe once every other month so most of my driving will be on road . Any suggestions will be great and i will take plenty of pictures as my jeep transforms.
You should go with the BFG all terrains instead of the MT's I have the MT's and prefer the quiet of the AT's, they are also a little less expensive. Just a suggestion.
plowe is offline   Reply With Quote Quick reply to this message
Unread 11-17-2007, 07:48 AM   #65
06flex
I am going to do both. I have an extra set of 5 wheels that i will have some AT's for around town and some MT's I can throw on when I go to play
Unread 11-17-2007, 10:42 AM   #66
raskull
If you wheel at all you will not regret buying an M/T. They wear faster, but the difference in any sort of mud is night and day.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (pic)
http://myjeeptj.com <- Write-ups on mods/maintenance/trips and a video/image gallery
Custom front bumper build
Custom rockers build
My build thread
raskull is offline   Reply With Quote Quick reply to this message
Unread 12-08-2007, 02:18 PM   #67
06flex
Well I took my chrome grill overlay and painted it black. I am not to sure about it right now but it is starting to grow on me. sorry slo9fo5oh I decide to keep it and do some experimenting.
Unread 12-08-2007, 02:24 PM   #68
Lostj
thats a good idea
so does any one have a tj grill overlay that they wanna sell me?
00'TJ
74'CJ5 For Sale
Lostj is offline   Reply With Quote Quick reply to this message
Unread 12-13-2007, 10:29 PM   #69
06flex
Well I received my 3/4" red side marker leds today. I will be installing them towmorrow after duck hunting and will post up installed pictures.
This is about the location i will be installing them
Unread 12-13-2007, 10:50 PM   #70
john NC
1979 CJ5
i think it would look even cooler if it was more of a matte black like that spray on bedliner
john NC is offline   Reply With Quote Quick reply to this message
Unread 12-13-2007, 11:03 PM   #71
06flex
yeah I was planning on doing that. I just had som black around so i used it. I am planning on sanding it a little and then spraying it this week.
Unread 12-13-2007, 11:45 PM   #72
john NC
1979 CJ5
OT, but have your brown dog MMLs loosened up a little since you first installed them? the first time i drove it after installing then they transfered a ton of vibration to the steering wheel and a little less to the pedals and rest of the tub. i've noticed in the week having them though, that this has gone away substantially and there's just minor vibration in the steering wheel now at idle which also vibrates the side mirrors. i'm guessing they just need to break in for a little or something. they're awesome mounts, and have completely cured my jeep of all it's driveline vibes, it accelerates so much smoother now and i kinda like being able to 'feel' the engine more. it is also very possible that i may have tightened the through bolt too much, or not enough
Unread 12-14-2007, 09:55 AM   #73
06flex
Yeah the if you over tighten the through bolts they will transmitt more vibes. I dont feel anything in my jeep. It may be that i am just use to it .
I really like the mounts they are a great product.
Unread 12-14-2007, 10:23 AM   #74
john NC
1979 CJ5
right on, it was late and i just tightened them to 48ft/lbs per 4x4xpolr instructions. i went back and read the brown dog instructions and they said to just make it snug, so i'll try loosening the through bolt a little
Unread 12-15-2007, 07:55 AM   #75
06flex
Today I installed my side marker lights. I installed them a little higher than I planned on but I ended up wanting them even with my taillights. It was a very easy install. Cutting and splicing in to the tail lights and soldering was the most time consuming thing. I used a 2 pole flat wire harnness to tap into the wiring harness so that they can be unpluged if need be.
