06flex's build (my build up) - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 06flex's build (my build up)
Spartan Locker's at all time LOW exclusive from ROCKRIDGE FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Bds fox ipf 2.0 racing series shocks now available at rock
Unread 10-27-2007, 02:57 PM   #46
06flex
I installed some cheap back up lights with a selectable switch today. When i say cheap i mean cheap. When i replace my bumper i will replace with some better ones but the hard part is done. I installed these in prep for my flush mounted leds form http://www.*******.com/dynamic/part_...t_num=LD-5570R. I have to stop buying all these little things and start to save for my lift.
Stu website supporter. http://www.stu-offroad.com/
One of the best jeep websites out there for reference. If you can help please do.
http://www.stu-offroad.com/misc/environment.htm
You didn't correct the problem, you only worked around the real problem.
06flex is offline   Reply With Quote Quick reply to this message
Unread 10-27-2007, 05:07 PM   #47
06flex
I also did an upgrade that (I have not dyno yet) had to increase my horse power and able to complete any trail ability.
Unread 10-27-2007, 10:48 PM   #48
beryl
install LED's yet? i have considered them but am curious how to deal with the evap canister on the passenger side.
06x-6speed...hard/soft top, BPE's, 2" coils, 1" PA BL, 32 bfg mt's, 15x8 MT alloys, big daddy rocker guards, flowmaster, RE gen II discos, rear bumper and tire carrier, 10" MTX sub with 800watt kenwood amp, mossy oak mats, sony stereo
beryl is offline   Reply With Quote Quick reply to this message
Unread 10-28-2007, 06:22 AM   #49
06flex
well I have an Unlimited so I have plenty of space and will not have to deal with the evap can.
Unread 10-28-2007, 12:07 PM   #50
beryl
aaah...lucky
Unread 11-02-2007, 05:30 PM   #51
06flex
Ordered my mesa led's last night. I will be installing them next Thursday . So I have read that the flasher I need for the led's is a EP-26 marked for 2-6 led's. I guess i will pick one of these up along with a hole saw from lowes. Anyone know what size hole the mesa's require...is it 4"?
Unread 11-15-2007, 11:07 PM   #52
06flex
Well I got my Mesa led tail lights today. I dry fitted them in a old water jug I had. It looks like a 4 3/8" hole for a tight fit. I cant seem to find this size hole saw at my local lowes so it looks like I am going to go with a 4 1/4" saw and file it to fit. Everything i have read says to use a 4 1/2" saw but that seems like it will be a loose fit. Any input on this would be good before I go cutting my tub tomorrow. I also heard the drill bit on the hole saw will tend to "slop up" the hole and cause a little bit bigger hole than advertised.
Here is the dry fit
Unread 11-16-2007, 12:30 AM   #53
06flex
just tried 4 1/2" hole in a box. Seems to be a good fit. Its not as tight as the 4 3/8 hole but i think that the 4.5" hole will transfer less vibes to the light with the looser fit maybe leading to a longer life of the light
The grommet calls for a 4.56-4.47" hole
http://www.truck-lite.com/webapp/wcs...3976&langId=-1
Unread 11-16-2007, 12:35 AM   #54
eclipse27
I used a 4.5 and it worked just fine.
4-4.5 inch susp. lift. 1 in performance acs. body lift. 5 in offroad foglights. Brushgaurd. Atoz corner armors.Round 4in taillights.D35/30 combo. upgraded horn.radio.8inbazzoka tube.highlift jack. 1.5in wheel spacers. 33' goodyear wrangler mt's.
eclipse27 is offline   Reply With Quote Quick reply to this message
Unread 11-16-2007, 12:40 AM   #55
06flex
Cool. I think thats what i am going to go with.
Unread 11-16-2007, 01:49 PM   #56
TXST8tj
i have to say, i really like how you have paid attention to the small stuff. it's not always as much fun as a lift or big tires, but it's all necessary for the overall build. it is also satisfying to get a lot of small stuff done while waiting to do the big stuff.
great lookin jeep!!
oh yeah, i may have missed it the explanation, but originally you bought the JKS BMML and then i saw you got the brown dog MML. did you not care for the MML spacer?
TXST8tj is offline   Reply With Quote Quick reply to this message
Unread 11-16-2007, 02:02 PM   #57
06flex
Thanks...No I decided to go with a whole new motor mount instead. Those extension bolts worried me(I think I have OCD) so I just went with new mounts.
Unread 11-16-2007, 02:12 PM   #58
TXST8tj
haha...fair enough. in the end, that which your motor is attached to should not be something that worries you.
on a side note, a friend of mine runs the JKS BMML and he has no problems with it at all. there is definitely nothing wrong with a whole new unit though.
Unread 11-16-2007, 02:13 PM   #59
06flex
Well I did it I cut two 4.5" holes in my tub. Install was easy with the hole saw. I used the EP26 flasher and in seems to work great except for when i try to use my selectable back up light switch in the on postion for reverse gear the lights seem to stay on even when not in reverse? Not sure why that is but anyway here it is.
Unread 11-16-2007, 04:01 PM   #60
rubicon35
looks good man. i did the mesa leds too. very pleased with the turnout. im in the middle of my build now too. just waiting for wheels have everything else. its a b**** waiting tho!
rubicon35 is offline   Reply With Quote Quick reply to this message
