06flex's build (my build up) - Page 9 - JeepForum.com
post #121 of 132 Old 06-22-2008, 09:03 PM Thread Starter
06flex
06flex's Avatar
Originally Posted by jluttrell68 View Post
You never showed us the finished product!
Ran out of time I will have to finish it up this week end along with my front diff. I also changed my speedo gear this weekend as well. Its nice to know how fast I am really going again.
Stu website supporter.
One of the best jeep websites out there for reference. If you can help please do.
You didn't correct the problem, you only worked around the real problem.
06flex is offline
post #122 of 132 Old 06-23-2008, 05:55 PM
Timmah707
Timmah707's Avatar
Where'd you get your speedo gear? Now that you've mentioned it, I'd kinda like to know how fast I'm going too
BTW, Great build thread! Been watching for a while
5.5" RE Long Arm, RE Monotubes, Gen. 2 Discos, 15x10 black steel, 35" BFG Muds, SYE, 30 spline chromoly rear shafts, 27 spline chromoly front shafts, Lock-Right Auto front, Ox Locker rear, 4.88s, LoD Xpedition Series Rear Bumper Tire Carrier
Blue Jeep Club Member #268
J ust
E mpty
E very
P ocket
Timmah707 is offline
post #123 of 132 Old 06-23-2008, 07:32 PM Thread Starter
06flex
06flex's Avatar
You can get it from your dealer. Just take them the part# you need. They may not have the size you need but they can order it and have it in a day or two. The guy at the parts counter(at my dealer) argued with me and was rude so i took my business else where. So I bought mine from Quadratec (which i hated to pay shipping but did not want to give the dealer my $)
06flex is offline
post #124 of 132 Old 06-24-2008, 02:36 PM
Timmah707
Timmah707's Avatar
Arguing with a customer over buying a part?! If you don't mind me asking, why would he argue with you?
P.S.- thanks for the tip!
J ust
E mpty
E very
P ocket
post #125 of 132 Old 06-27-2008, 07:48 PM Thread Starter
06flex
06flex's Avatar
Well the part # that went with the speedo gear did not match my year model and make. Basically No LJ came with a 31 tooth gear so he was telling me it would not fit.
06flex is offline
post #126 of 132 Old 06-27-2008, 07:58 PM Thread Starter
06flex
06flex's Avatar
Today I took on two problems. The first was to take care of where the tie rod was hitting the swaybar link bracket.
To do this I cut a small 1/4" flat bar and drilled two holes to raise the swaybar link up about 2".
I then ground down the stock swaybar bracket to clear the tie rod.
My other problem was that the swaybar links that came with my lift were about 2" two short. So while raising the links to clear the tie rod it also solved my problem of the short links.
berfore
after
06flex is offline
post #127 of 132 Old 06-28-2008, 10:59 AM Thread Starter
06flex
06flex's Avatar
After sanding it down good and a good coat of primer I have it back on the jeep (the grill overlay that was chipping bad because of my poor prep last time)
06flex is offline
post #128 of 132 Old 07-07-2008, 04:45 PM Thread Starter
06flex
06flex's Avatar
Installed my front riddler diff cover on Saturday. I also cut my front bumper down a little bit. I did this really for looks only and to kill time before the race started. I hope to be ordering a AA sye and TW drive shaft soon with some sort of tummy tuck.
06flex is offline
post #129 of 132 Old 07-07-2008, 05:30 PM
shawn1980
nice thread keep it up
shawn1980 is offline
post #130 of 132 Old 07-21-2008, 03:40 PM Thread Starter
06flex
06flex's Avatar
Today I removed my old back up lights 2 55W driving lights and replaced them with some flush mounted 7watt (I think) incandescent bulb. They are still installed with a spdt switch with a relay so I can either turn them on when I want or just when it is put in reverse. My next project is to install these same lights on my boat trailer and install a flat 5 pin trail harness on the jeep so I can see to back the boat down the ramp on those early duck hunting mornings.
old lights
new lights
06flex is offline
post #131 of 132 Old 12-03-2009, 01:52 AM
YJjake12
Looks more like a expensive part buy and bolt on then a true build. But one of the best looking TJ's I like. I'd swap them axles soon. And don't buy them cheep ruby 44s.
BULACH RACING!
More Jeeps and parts then I know what to do with.
YJjake12 is offline
post #132 of 132 Old 07-03-2010, 10:26 PM
DJdave
This is defintely a tasty jeep.
DJdave is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
87 YJ Build leadfoot_yj YJ Wrangler Technical Forum 27 01-06-2009 11:08 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
