06flex's build (my build up) - Page 5 - JeepForum.com
post #61 of 132 Old 11-16-2007, 06:26 PM Thread Starter
06flex
06flex's Avatar
Originally Posted by rubicon35
looks good man. i did the mesa leds too. very pleased with the turnout. im in the middle of my build now too. just waiting for wheels have everything else. its a b**** waiting tho!
I hear ya. I have ran out of little things to do so now I have to wait on the lift and tires. Then I will be waiting on gears and a selectable locker for the rear. I guess it will never end. I am sure I will find some side projects like rockers,lunchbox locker for the front, and other mis. armor to keep me busy untill the tires and lift.
Stu website supporter.
One of the best jeep websites out there for reference. If you can help please do.
You didn't correct the problem, you only worked around the real problem.
06flex is offline
post #62 of 132 Old 11-16-2007, 08:55 PM
LimeGreen
LimeGreen's Avatar
Awesome! Quick question, Can you show me a pick of the hole saw you used for the led's? Not sure what that looks like. Thanks
LimeGreen is offline
post #63 of 132 Old 11-16-2007, 08:59 PM Thread Starter
06flex
06flex's Avatar
http://www.lowes.com/lowes/lkn?actio...72A&lpage=none
This is the one I used. If I had to do it again i would have used a 4.25" one and filed it out to fit. The 4.5" hole works just fine but it is not a real tight fit. It by no means is going anywhere but I always am looking for something better
06flex is offline
post #64 of 132 Old 11-16-2007, 09:26 PM
plowe
Originally Posted by 06flex
I probaly will wheel maybe once every other month so most of my driving will be on road . Any suggestions will be great and i will take plenty of pictures as my jeep transforms.
You should go with the BFG all terrains instead of the MT's I have the MT's and prefer the quiet of the AT's, they are also a little less expensive. Just a suggestion.
plowe is offline
post #65 of 132 Old 11-17-2007, 07:48 AM Thread Starter
06flex
06flex's Avatar
I am going to do both. I have an extra set of 5 wheels that i will have some AT's for around town and some MT's I can throw on when I go to play
06flex is offline
post #66 of 132 Old 11-17-2007, 10:42 AM
raskull
raskull's Avatar
If you wheel at all you will not regret buying an M/T. They wear faster, but the difference in any sort of mud is night and day.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #67 of 132 Old 12-08-2007, 02:18 PM Thread Starter
06flex
06flex's Avatar
Well I took my chrome grill overlay and painted it black. I am not to sure about it right now but it is starting to grow on me. sorry slo9fo5oh I decide to keep it and do some experimenting.
06flex is offline
post #68 of 132 Old 12-08-2007, 02:24 PM
Lostj
Lostj's Avatar
thats a good idea
so does any one have a tj grill overlay that they wanna sell me?
00'TJ
74'CJ5 For Sale
Lostj is offline
post #69 of 132 Old 12-13-2007, 10:29 PM Thread Starter
06flex
06flex's Avatar
Well I received my 3/4" red side marker leds today. I will be installing them towmorrow after duck hunting and will post up installed pictures.
This is about the location i will be installing them
06flex is offline
post #70 of 132 Old 12-13-2007, 10:50 PM
john NC
john NC's Avatar
i think it would look even cooler if it was more of a matte black like that spray on bedliner
john NC is offline
post #71 of 132 Old 12-13-2007, 11:03 PM Thread Starter
06flex
06flex's Avatar
yeah I was planning on doing that. I just had som black around so i used it. I am planning on sanding it a little and then spraying it this week.
06flex is offline
post #72 of 132 Old 12-13-2007, 11:45 PM
john NC
john NC's Avatar
OT, but have your brown dog MMLs loosened up a little since you first installed them? the first time i drove it after installing then they transfered a ton of vibration to the steering wheel and a little less to the pedals and rest of the tub. i've noticed in the week having them though, that this has gone away substantially and there's just minor vibration in the steering wheel now at idle which also vibrates the side mirrors. i'm guessing they just need to break in for a little or something. they're awesome mounts, and have completely cured my jeep of all it's driveline vibes, it accelerates so much smoother now and i kinda like being able to 'feel' the engine more. it is also very possible that i may have tightened the through bolt too much, or not enough
john NC is offline
post #73 of 132 Old 12-14-2007, 09:55 AM Thread Starter
06flex
06flex's Avatar
Yeah the if you over tighten the through bolts they will transmitt more vibes. I dont feel anything in my jeep. It may be that i am just use to it .
I really like the mounts they are a great product.
06flex is offline
post #74 of 132 Old 12-14-2007, 10:23 AM
john NC
john NC's Avatar
right on, it was late and i just tightened them to 48ft/lbs per 4x4xpolr instructions. i went back and read the brown dog instructions and they said to just make it snug, so i'll try loosening the through bolt a little
john NC is offline
post #75 of 132 Old 12-15-2007, 07:55 AM Thread Starter
06flex
06flex's Avatar
Today I installed my side marker lights. I installed them a little higher than I planned on but I ended up wanting them even with my taillights. It was a very easy install. Cutting and splicing in to the tail lights and soldering was the most time consuming thing. I used a 2 pole flat wire harnness to tap into the wiring harness so that they can be unpluged if need be.
06flex is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 01:23 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 03:21 PM
87 YJ Build leadfoot_yj YJ Wrangler Technical Forum 27 01-07-2009 12:08 AM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-28-2006 12:05 AM
