06 TCM location - JeepForum.com
post #1 of 7 Old 03-23-2010, 08:24 AM Thread Starter
roadkill
06 TCM location
I'm curious where they moved the TCM to on the 06's. I did the metalcloak fenders a few weeks ago and noticed that I didn't have the TCM on the fenders like other 42rle jeeps do. anyone know where they stuffed it? I also noticed that there was no battery temp sensor under the battery tray as well.
roadkill is offline
post #2 of 7 Old 03-23-2010, 08:47 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its integratred in to the PCM on the firewall by the battery.
That is why Jeep uses the term PCM.
Its a powertrain control module rather than just an engine control module (ECM).
Wheelin98TJ is offline
post #3 of 7 Old 03-23-2010, 10:05 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Count the number of plugs on the PCM. All TJ's up until they integrated the TCM into the PCM for the 42 RLE, had 3 plugs. Now those particular models have 4.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #4 of 7 Old 03-23-2010, 10:06 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
What do you call the ones that control the torque convertor lock-up and get input from the VSS?
I am Savvy
post #5 of 7 Old 03-23-2010, 11:58 AM
Wheelin98TJ
JEEP FREAK
I'd call it a computer.
post #6 of 7 Old 05-01-2010, 11:31 AM
Exerdoc
Ok, I've searched the forum and cannot find this info.
Where is the TCM located on an 04 Wrangler Rubicon???
Thanks.
T
'04 TJ Rubicon, 4.5" spring lift with 1" BL, 37" KM2s on 17" steel wheels, Ramsey winch. Genright Flat Fenders; Currie Steering.
Exerdoc is offline
post #7 of 7 Old 05-01-2010, 12:12 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Thanks.
T
Last I checked, they were right in front of the brake booster.
I am Savvy
ICM location rrisher YJ Wrangler Technical Forum 2 11-05-2008 01:48 PM
Name this location!!! VegasJeep JK Wrangler Technical Forum 32 10-14-2008 05:10 PM
ECU location? TJ-Tera TJ Wrangler Technical Forum 5 02-10-2007 11:50 PM
PCV location romiin YJ Wrangler Technical Forum 3 09-19-2006 12:00 AM
sub box location ginsy YJ Wrangler Technical Forum 9 03-08-2005 12:02 AM
